查看: 12537|回复: 2
[现网案例] 怎么看IFC的签约数据呢 [复制链接]
发表于 2016-1-14 10:36:03 |只看该作者 |倒序浏览
以下是SAA的信令截图
Diameter Protocol
    Version: 0x01
    Length: 1632
    Flags: 0x40, Proxyable
        0... .... = Request: Not set
        .1.. .... = Proxyable: Set
        ..0. .... = Error: Not set
        ...0 .... = T(Potentially re-transmitted message): Not set
        .... 0... = Reserved: Not set
        .... .0.. = Reserved: Not set
        .... ..0. = Reserved: Not set
        .... ...0 = Reserved: Not set
    Command Code: 301 Server-Assignment
    ApplicationId: 3GPP Cx (16777216)
    Hop-by-Hop Identifier: 0x096018fb
    End-to-End Identifier: 0x0396bef8
    [Request In: 24]
    [Response Time: 0.056822000 seconds]
    AVP: Session-Id(263) l=57 f=-M- val=njscscf11bhw.js.chinamobile.com;70451213;3838;150
        AVP Code: 263 Session-Id
        AVP Flags: 0x40
            0... .... = Vendor-Specific: Not set
            .1.. .... = Mandatory: Set
            ..0. .... = Protected: Not set
            ...0 .... = Reserved: Not set
        AVP Length: 57
        Session-Id: njscscf11bhw.js.chinamobile.com;70451213;3838;150
        Padding: 000000
    AVP: Vendor-Specific-Application-Id(260) l=32 f=-M-
        AVP Code: 260 Vendor-Specific-Application-Id
        AVP Flags: 0x40
        AVP Length: 32
        Vendor-Specific-Application-Id: 0000010a4000000c000028af000001024000000c01000000
            AVP: Vendor-Id(266) l=12 f=-M- val=10415
                AVP Code: 266 Vendor-Id
                AVP Flags: 0x40
                AVP Length: 12
                Vendor-Id: 10415
                VendorId: 3GPP (10415)
            AVP: Auth-Application-Id(258) l=12 f=-M- val=3GPP Cx (16777216)
                AVP Code: 258 Auth-Application-Id
                AVP Flags: 0x40
                AVP Length: 12
                Auth-Application-Id: 3GPP Cx (16777216)
    AVP: Auth-Session-State(277) l=12 f=-M- val=NO_STATE_MAINTAINED (1)
        AVP Code: 277 Auth-Session-State
        AVP Flags: 0x40
        AVP Length: 12
        Auth-Session-State: NO_STATE_MAINTAINED (1)
    AVP: Origin-Host(264) l=67 f=-M- val=NJHSS04FE02BHW.nj.js.node.ims.mnc000.mcc460.3gppnetwork.org
        AVP Code: 264 Origin-Host
        AVP Flags: 0x40
        AVP Length: 67
        Origin-Host: NJHSS04FE02BHW.nj.js.node.ims.mnc000.mcc460.3gppnetwork.org
        Padding: 00
    AVP: Origin-Realm(296) l=41 f=-M- val=ims.mnc000.mcc460.3gppnetwork.org
        AVP Code: 296 Origin-Realm
        AVP Flags: 0x40
        AVP Length: 41
        Origin-Realm: ims.mnc000.mcc460.3gppnetwork.org
        Padding: 000000
    AVP: Supported-Features(628) l=56 f=V-- vnd=TGPP
        AVP Code: 628 Supported-Features
        AVP Flags: 0x80
            1... .... = Vendor-Specific: Set
            .0.. .... = Mandatory: Not set
        AVP Length: 56
        AVP Vendor Id: 3GPP (10415)
        Supported-Features: 0000010a4000000c000028af0000027580000010000028af...
                AVP Flags: 0x40
                AVP Length: 12
                Vendor-Id: 10415
            AVP: Feature-List-ID(629) l=16 f=V-- vnd=TGPP val=1
                AVP Code: 629 Feature-List-ID
                AVP Flags: 0x80
                AVP Length: 16
                Feature-List-ID: 1
            AVP: Feature-List(630) l=16 f=V-- vnd=TGPP val=7
                AVP Code: 630 Feature-List
                AVP Flags: 0x80
                AVP Length: 16
                Feature-List: 7
                CX Feature-List Flags: 0x00000007
                    0000 0000 0000 0000 0000 0000 0000 .... = Spare: 0x00000000
                    .... .... .... .... .... .... .... 0... = P-CSCF Restoration mechanism: Not supported
                    .... .... .... .... .... .... .... .1.. = IMS Restoration Indication: Supported
                    .... .... .... .... .... .... .... ..1. = Alias Indication: Supported
                    .... .... .... .... .... .... .... ...1 = Shared IFC Sets: Supported
    AVP: Result-Code(268) l=12 f=-M- val=DIAMETER_SUCCESS (2001)
        AVP Code: 268 Result-Code
        AVP Flags: 0x40
        AVP Length: 12
        Result-Code: DIAMETER_SUCCESS (2001)
    AVP: User-Name(1) l=57 f=-M- val=460079052427191@ims.mnc007.mcc460.3gppnetwork.org
        AVP Code: 1 User-Name
        AVP Flags: 0x40
        AVP Length: 57
        User-Name: 460079052427191@ims.mnc007.mcc460.3gppnetwork.org
        Padding: 000000
    AVP: User-Data(606) l=1095 f=VM- vnd=TGPP val=3c3f786d6c2076657273696f6e3d22312e302220656e636f...
        AVP Code: 606 User-Data
        AVP Flags: 0xc0
        AVP Length: 1095
        User-Data: 3c3f786d6c2076657273696f6e3d22312e302220656e636f...
        eXtensible Markup Language
            <?xml
                version="1.0"
                encoding="UTF-8"
            <IMSSubscription>
                <PrivateID>
                    </PrivateID>
                <ServiceProfile>
                    <PublicIdentity>
                        <BarringIndication>
                            0
                            </BarringIndication>
                        <Identity>
                            sip:+8614705244847@js.ims.mnc000.mcc460.3gppnetwork.org
                            </Identity>
                        <Extension>
                            <IdentityType>
                                0
                                </IdentityType>
                            <Extension>
                                <AliasIdentityGroupID>
                                    1
                                    </AliasIdentityGroupID>
                                </Extension>
                            </Extension>
                        </PublicIdentity>
                    <PublicIdentity>
                        <BarringIndication>
                            1
                        <Identity>
                            sip:460079052427191@ims.mnc007.mcc460.3gppnetwork.org
                            </Identity>
                        <Extension>
                            <IdentityType>
                                0
                                </IdentityType>
                            <Extension>
                                    1
                                </Extension>
                            </Extension>
                        </PublicIdentity>
                    <PublicIdentity>
                        <BarringIndication>
                            0
                        <Identity>
                            tel:+8614705244847
                            </Identity>
                        <Extension>
                            <IdentityType>
                                0
                                </IdentityType>
                            <Extension>
                                    1
                                </Extension>
                            </Extension>
                        </PublicIdentity>
                    <Extension>
                        <SharedIFCSetID>
                            903
                            </SharedIFCSetID>
                        <SharedIFCSetID>
                            902
                            </SharedIFCSetID>
                        <SharedIFCSetID>
                            901
                            </SharedIFCSetID>
                        </Extension>
                    </ServiceProfile>
                </IMSSubscription>
        Padding: 00
    AVP: Charging-Information(618) l=156 f=VM- vnd=TGPP
        AVP Code: 618 Charging-Information
        AVP Flags: 0xc0
        AVP Length: 156
        Charging-Information: 0000026dc0000021000028af6161613a2f2f504343462e68...
            AVP: Primary-Charging-Collection-Function-Name(621) l=33 f=VM- vnd=TGPP val=aaa://PCCF.huawei.com
                AVP Code: 621 Primary-Charging-Collection-Function-Name
                AVP Flags: 0xc0
                AVP Length: 33
                Primary-Charging-Collection-Function-Name: aaa://PCCF.huawei.com
                Padding: 000000
            AVP: Primary-Event-Charging-Function-Name(619) l=33 f=VM- vnd=TGPP val=aaa://PECF.huawei.com
                AVP Code: 619 Primary-Event-Charging-Function-Name
                AVP Flags: 0xc0
                AVP Length: 33
                Primary-Event-Charging-Function-Name: aaa://PECF.huawei.com
                Padding: 000000
            AVP: Secondary-Event-Charging-Function-Name(620) l=33 f=VM- vnd=TGPP val=aaa://SECF.huawei.com
                AVP Code: 620 Secondary-Event-Charging-Function-Name
                AVP Flags: 0xc0
                AVP Length: 33
                Secondary-Event-Charging-Function-Name: aaa://SECF.huawei.com
                Padding: 000000
            AVP: Secondary-Charging-Collection-Function-Name(622) l=33 f=VM- vnd=TGPP val=aaa://SCCF.huawei.com
                AVP Code: 622 Secondary-Charging-Collection-Function-Name
                AVP Flags: 0xc0
                AVP Length: 33
                Secondary-Charging-Collection-Function-Name: aaa://SCCF.huawei.com
                Padding: 000000
    AVP: Loose-Route-Indication(638) l=16 f=V-- vnd=TGPP val=LOOSE_ROUTE_NOT_REQUIRED (0)
        AVP Code: 638 Loose-Route-Indication
        AVP Flags: 0x80
        AVP Length: 16
        Loose-Route-Indication: LOOSE_ROUTE_NOT_REQUIRED (0)
发表于 2016-1-14 14:46:24 |只看该作者
是这样的。iFC包括普通和共享iFC。下图是他们的对比:
可以看出来,共享iFC维护更方便,信令开销也更小。所以你的包也是共享iFC。看不到实质性的数据,只有90x这几个数字ID。这是正常的。
普通即标准的iFC应包含以下数据:
1)AS的地址:即触发到哪个或哪些AS。
2)AS Priority:哪个AS先触发,哪个AS后触发。
3)Default Handling:当AS没有响应的时候,CSCF的默认处理方式。
4)Trigger Points:触发点。
5)Subscribed Media:订阅媒体。
6)Optional Service Information:可选的业务信息。
以下是规范中关于共享iFC的说明:
- Shared iFC sets
This feature is applicable for the SAR/SAA and PPR/PPA command pairs.
If both the HSS and the S-CSCF support this feature, subsets of Initial Filter Criteria may be shared by several service profiles and the HSS shall download the shared iFC sets implicitly by downloading the unique identifiers of the shared iFC sets to the S-CSCF. By means of a locally administered database, the S-CSCF then maps the downloaded identifiers onto the shared iFC sets.
发表于 2016-5-26 14:25:18 |只看该作者
是哪個AVP值得知是iFC消息或是由哪裡開始呢?
GMT+8, 2025-11-24 05:29 , Processed in 0.024840 second(s), 12 queries .
