查看: 6453|回复: 6
3GPP哪个规范是讲参数的 [复制链接]
发表于 2015-5-10 12:21:15 |只看该作者 |倒序浏览
recovery (restart counter) 是在哪个3GPP规范定义的,麻烦给指导一下,谢谢!!
发表于 2015-5-10 14:55:10 |只看该作者
GTPV1的吗?TS29.060里啊。携带在echo response消息里。
发表于 2015-5-10 17:40:26 |只看该作者
GTPV2的吧   APN重定向时,携带在MME想SGW发送的create session request 里面的,也是在29.060吗?  谢谢
发表于 2015-5-10 22:32:51 |只看该作者
GTPV2是29.274,create session request消息里没有restart counter,都是在echo消息里的。
发表于 2015-5-11 12:54:13 |只看该作者
recovery=250  不知有没有特殊的含义 ,没查出来!多谢指教!
发表于 2015-5-11 22:07:46 |只看该作者
帮你查了下规范,如下:
Across GTP-C based interfaces an SGSN, GGSN, MME, SGW, PGW and ePDG utilize either GTPv1-C or GTPv2-C Echo Request and Echo Response messages or GTP-C messages containing the Recovery Information Element to detect and handle a restart.
A GTP-C entity shall maintain two Restart counters:
-         in volatile memory a remote Restart counter of a peer with which the entity is in contact;
-        in non-volatile memory own, or local Restart counter that was sent to a peer.
After a GTP-C entity has restarted, it shall immediately increment all local Restart counters and shall clear all remote Restart counters.
A GTP-C entity may have a common local Restart counter for all peers, or it may have a separate local Restart counter for each peer.
A GTP-C entity may probe the liveliness of each peer with which it is in contact by sending an Echo Request message (see clause 20 "Path management procedures") . The presence of the Restart counter in Echo Request or in a GTP-C message depends on the GTP-C version and therefore is specified in 3GPP TS 29.060 [8] and 3GPP TS 29.274 [13], respectively.
The GTP-C entity that receives a Recovery Information Element in an Echo Response or in another GTP-C message from a peer, shall compare the received remote Restart counter value with the previous Restart counter value stored for that peer entity.
-        If no previous value was stored the Restart counter value received in the Echo Response or in the GTP-C message shall be stored for the peer.
-        If the value of a Restart counter previously stored for a peer is smaller than the Restart counter value received in the Echo Response message or the GTP-C message, taking the integer roll-over into account, this indicates that the entity that sent the Echo Response or the GTP-C message has restarted. The received, new Restart counter value shall be stored by the receiving entity, replacing the value previously stored for the peer.
-        If the value of a Restart counter previously stored for a peer is larger than the Restart counter value received in the Echo Response message or the GTP-C message, taking the integer roll-over into account, this indicates a possible race condition (newer message arriving before the older one). The received new Restart counter value shall be discarded and an error may be logged.
翻译过来就是,
一个GTP-C的网元需要维护两个restart counter,一个是对端的,一个是自己的。当自己发生重启,将把本地restart counter值+1,然后发给对方。
对方如何处理呢?
- 每次受到echo response消息里的restart counter值(假设是值1)都保存下来,存到本地,然后后续还会继续受到GTP-C消息里的restart counter(假设值1)和进行比对,如果值1大于本地保存的值2,则判断出来对方发生了重启。
发表于 2015-6-27 10:30:41 |只看该作者
admin 发表于 2015-5-11 22:07
帮你查了下规范,如下:
Across GTP-C based interfaces an SGSN, GGSN, MME, SGW, PGW and ePDG utiliz ...
十分感谢!!!
GMT+8, 2025-12-14 06:45 , Processed in 0.042475 second(s), 12 queries .
