查看: 3528|回复: 2
APN区分大小写吗? [复制链接]
Rank: 4Rank: 4Rank: 4Rank: 4
发表于 2014-2-25 16:35:02 |只看该作者 |倒序浏览
今天在统计数据的时候,发现一个神奇的现象,CMNET的速率,比之cmnet的速率小很多。统计的一天,15个RNC均是这种现象。
是巧合呢,还是巧合呢?
发表于 2014-2-25 21:14:18 |只看该作者
不分哦。由TS23 003定义。如下
The APN Operator Identifier is placed afterthe APN Network Identifier. An APN consisting of both the Network Identifierand Operator Identifier corresponds to a DNS name of a GGSN/PGW; the APN has,after encoding as defined in the paragraph below, a maximum length of 100octets.
The encoding of the APN shall follow theName Syntax defined in RFC 2181 [18], RFC 1035 [19] andRFC 1123 [20]. The APN consists of one or more labels. Each label iscoded as a one octet length field followed by that number of octets coded as 8bit ASCII characters. Following RFC 1035 [19] the labels shallconsist only of the alphabetic characters (A-Z and a-z), digits (0-9) and thehyphen (-). Following RFC 1123 [20], the label shall begin and endwith either an alphabetic character or a digit. The case of alphabeticcharacters is not significant. The APN is not terminated by a length byte ofzero.
发表于 2014-3-2 23:19:21 |只看该作者
协议的确这么做的。可以想象,入股区分大小写,那还不把手机客户给整死呢
GMT+8, 2025-11-24 08:10 , Processed in 0.023685 second(s), 12 queries .
