查看: 3383|回复: 0
最新IR33 GPRS漫游指导标准 6.0 [复制链接]
版主
发表于 2013-8-19 11:00:55 |只看该作者 |倒序浏览
GPRS Roaming Guidelines
Table of Contents
1.1        Overview......................................................................................................... 4
1.1.1    Scope.............................................................................................................. 4
1.1.2    Architecture and Interfaces............................................................................. 4
1.2        Definition of Terms.......................................................................................... 5
1.3        Document Cross-References......................................................................... 5
3.1        Introduction...................................................................................................... 6
3.2        Inter-PLMN IP backbone network requirements............................................ 6
3.2.1    IP address & routing....................................................................................... 6
3.2.2    DNS................................................................................................................. 6
3.3        Access Point Name (APN)............................................................................. 7
3.3.1    General............................................................................................................ 7
3.3.2    APN Components........................................................................................... 7
3.3.2.1      Overview............................................................................................... 7
3.3.2.2      Network Identifier.................................................................................. 7
3.3.2.3      Operator Identifier................................................................................. 9
3.3.3    Types of APN................................................................................................ 10
3.3.3.1      General................................................................................................ 10
3.3.3.2      Service APN....................................................................................... 10
3.3.3.3      Wildcard APN...................................................................................... 10
3.4        Addressing..................................................................................................... 10
3.4.1    UE Addressing.............................................................................................. 10
3.4.1.1      SS7...................................................................................................... 10
3.4.1.2      IP......................................................................................................... 10
3.4.2    Network Element Addressing....................................................................... 12
3.4.3    The Transition to IPv6................................................................................... 13
3.4.3.1      General................................................................................................ 13
3.4.3.2      Home GGSN Roaming....................................................................... 13
3.4.3.3      Visited GGSN Roaming...................................................................... 14
3.5        PDP Types.................................................................................................... 14
3.5.1    Introduction.................................................................................................... 14
3.5.2    No PDP Context........................................................................................... 14
3.5.3    IPv4 only PDP Context................................................................................. 15
3.5.4    IPv6 only PDP Context................................................................................. 15
3.5.5    IPv4 only PDP Context and IPv6 only PDP Context................................... 16
3.5.6    IPv4 and IPv6 PDP Context......................................................................... 16
4.1        Introduction.................................................................................................... 16
4.2        Control of multiple, concurrent PDP Contexts............................................. 16
4.2.1    Definition........................................................................................................ 16
4.2.2    Recommendations........................................................................................ 17
4.3        Flow Based Charging.................................................................................... 17
4.3.1    Definition........................................................................................................ 17
4.3.2    Recommendations........................................................................................ 18
4.4        Automatic Device Detection......................................................................... 18
4.4.1    Definition........................................................................................................ 18
4.4.2    Recommendations........................................................................................ 18
4.5        Direct Tunnel Functionality........................................................................... 18
4.5.1    Definition........................................................................................................ 18
4.5.2    Recommendations........................................................................................ 19
4.6        SGSN sharing............................................................................................... 19
4.6.1    Definition........................................................................................................ 19
4.6.2    Recommendations........................................................................................ 19
6.1        GTP version 0 and version 1 Interworking Problem..................................... 19
6.1.1    Introduction.................................................................................................... 19
6.1.2    VPLMN solution............................................................................................ 20
6.1.3    HPLMN solution............................................................................................ 20
6.2        IP source address of GTPv1 response messages....................................... 20
6.3        GPRS QoS Classes...................................................................................... 21
Document History...................................................................................................... 22
Other Information....................................................................................................... 22
GMT+8, 2025-11-24 06:13 , Processed in 0.024450 second(s), 13 queries .
