查看: 3284|回复: 0
GMM和SM Cause和消息码总结 [复制链接]
发表于 2013-7-25 21:11:20 |只看该作者 |倒序浏览
以下为从规范中整理出来的GMM和SM的Cause和消息码,便于外语不好,看规范头痛的战友们查阅。
1、GMM cause和消息码
[tr] [/tr]
GMM cause information element
Cause value (octet 2)
Bits
8
7654321
0
0000010IMSI unknown in HLR
0
0000011Illegal MS
0
0000101IMEI not accepted
0
0000110Illegal ME
0
0000111GPRS services  not allowed
0
0001000GPRS services and non-GPRS  services not allowed
0
0001001MS identity cannot be derived  by the network
0
0001010Implicitly detached
0
0001011PLMN not allowed
0
0001100Location Area not allowed
0
0001101Roaming not allowed in this  location area
0
0001110GPRS services not allowed in  this PLMN
0
0001111No Suitable Cells In Location  Area
0
0010000MSC temporarily not reachable
0
0010001Network failure
0
0010100MAC failure
0
0010101Synch failure
0
0010110Congestion
0
0010111GSM authentication unacceptable
0
0011001Not authorized for this CSG
0
0011100SMS provided via GPRS in this  routing area
0
0101000No PDP context activated
0
0110000}
to } retry upon entry into a new cell
0
0111111}
0
1011111Semantically incorrect message
0
1100000Invalid mandatory information
0
1100001Message type non-existent or  not implemented
0
1100010Message type not compatible  with the protocol state
0
1100011Information element  non-existent or not implemented
0
1100100Conditional IE error
0
1100101Message not compatible with the  protocol state
0
1101111Protocol error, unspecified
Message types for GPRS mobility management
Bits
87654321
00------Mobility management messages
00000001Attach request
00000010Attach accept
00000011Attach complete
00000100Attach reject
00000101Detach request
00000110Detach accept
00001000Routing area update request
00001001Routing area update accept
00001010Routing area update complete
00001011Routing area update reject
00001100Service Request
00001101Service Accept
00001110Service Reject
00010000P-TMSI reallocation  command
00010001P-TMSI reallocation  complete
00010010Authentication and ciphering  req
00010011Authentication and ciphering  resp
00010100Authentication and ciphering  rej
00011100Authentication and ciphering  failure
00010101Identity request
00010110Identity response
00100000GMM status
00100001 GMM information
2、SM cause和消息码
SM cause information  element
bitbitbitbitbitbitbitbit
8
7
6
5
4
3
2
1
0
0
0
0
1
0
0
0
Operator Determined Barring
0
0
0
1
1
0
0
0
MBMS bearer capabilities  insufficient for the service
0
0
0
1
1
0
0
1
LLC or SNDCP failure(A/Gb mode  only)
0
0
0
1
1
0
1
0
Insufficient resources
0
0
0
1
1
0
1
1
Missing or unknown APN
0
0
0
1
1
1
0
0
Unknown PDP address or PDP type
0
0
0
1
1
1
0
1
User authentication failed
0
0
0
1
1
1
1
0
Activation rejected by GGSN, Serving  GW or PDN GW
0
0
0
1
1
1
1
1
Activation rejected,  unspecified
0
0
1
0
0
0
0
0
Service option not supported
0
0
1
0
0
0
0
1
Requested service option not  subscribed
0
0
1
0
0
0
1
0
Service option temporarily out of  order
0
0
1
0
0
0
1
1
NSAPI already used (not sent)
0
0
1
0
0
1
0
0
Regular deactivation
0
0
1
0
0
1
0
1
QoS not accepted
0
0
1
0
0
1
1
0
Network failure
0
0
1
0
0
1
1
1
Reactivation requested
0
0
1
0
1
0
0
0
Feature not supported
0
0
1
0
1
0
0
1
Semantic error in the TFT  operation
0
0
1
0
1
0
1
0
Syntactical error in the TFT  operation
0
0
1
0
1
0
1
1
Unknown PDP context
0
0
1
0
1
1
0
0
Semantic errors in packet  filter(s)
0
0
1
0
1
1
0
1
Syntactical errors in packet  filter(s)
0
0
1
0
1
1
1
0
PDP context without TFT already  activated
0
0
1
0
1
1
1
1
Multicast group membership  time-out
0
0
1
1
0
0
0
0
Request rejected, BCM violation
0
0
1
1
0
0
1
0
PDP type IPv4 only allowed
0
0
1
1
0
0
1
1
PDP type IPv6 only allowed
0
0
1
1
0
1
0
0
Single address bearers only  allowed
0
0
1
1
1
0
0
0
Collision with network initiated  request
0
0
1
1
1
1
0
0
Bearer handling not supported
0
1
0
0
0
0
0
1
Maximum number of PDP contexts  reached
0
1
0
0
0
0
1
0
Requested APN not supported in  current RAT and PLMN combination
0
1
0
1
0
0
0
1
Invalid transaction identifier  value
0
1
0
1
1
1
1
1
0
1
1
0
0
0
0
0
0
1
1
0
0
0
0
1
0
1
1
0
0
0
1
0
0
1
1
0
0
0
1
1
0
1
1
0
0
1
0
0
0
1
1
0
0
1
0
1
0
1
1
0
1
1
1
1
0
1
1
1
0
0
0
0
APN restriction value incompatible  with active PDP context
Message types for GPRS session management
Bits
87654321
01------Session management messages
01000001Activate PDP context request
01000010Activate PDP context  accept
01000011Activate PDP context  reject
01000100Request PDP context  activation
01000101Request PDP context activation  rej.
01000110Deactivate PDP context  request
01000111Deactivate PDP context  accept
01001000Modify PDP context  request(Network to MS direction)
01001001Modify PDP context accept (MS  to network direction)
01001010Modify PDP context request(MS  to network direction)
01001011Modify PDP context accept  (Network to MS direction)
01001100Modify PDP context reject
01001101Activate secondary PDP context  request
01001110Activate secondary PDP context  accept
01001111Activate secondary PDP context  reject
01010000Reserved: was allocated in  earlier phases of the protocol
01010001Reserved: was allocated in  earlier phases of the protocol
01010010Reserved: was allocated in  earlier phases of the protocol
01010011Reserved: was allocated in  earlier phases of the protocol
01010100Reserved: was allocated in  earlier phases of the protocol
01010101SM Status
01010110Activate MBMS Context Request
01010111Activate MBMS Context Accept
01011000Activate MBMS Context Reject
01011001Request MBMS Context Activation
01011010Request MBMS Context Activation  Reject
01011011Request Secondary PDP Context  Activation
01011100Request Secondary PDP Context  Activation Reject
01011101Notification
GMT+8, 2025-11-24 06:29 , Processed in 0.031486 second(s), 11 queries .
