查看: 9513|回复: 6
[FAQ] 什么情况下UE应该发起到电路域的联合附着流程?(而非仅附着到EPS域) [复制链接]
发表于 2013-3-12 09:27:27 |只看该作者 |倒序浏览
根据规范24301的规定,“The combined attach procedure is used by a UE in CS/PS mode 1 or CS/PS mode 2 of operation to attach for both EPS and non-EPS services, or both EPS services and "SMS only".
The combined attach procedure is also used by a UE in CS/PS mode 1 or CS/PS mode 2 of operation to attach for EPS services if it is already IMSI attached for non-EPS services.
When the UE initiates a combined attach procedure, the UE shall indicate "combined EPS/IMSI attach" in the EPS attach type IE.”
也就是说UE的工作模式在CS/PS mode 1或CS/PS mode 2时,应该发起联合附着。
那UE什么情况下会工作在CS/PS mode 1或CS/PS mode 2呢?规范也做了一些说明(可能还有漏掉的哈):
“A UE configured to use CS fallback, shall operate in CS/PS mode 1 or CS/PS mode 2. Such UE may also be configured to use IMS, in which case the voice domain preference as defined in 3GPP TS 24.167 [13B] shall be used for the selection of the domain for originating voice communication services.
A UE configured to use SMS over SGs, but not configured to use CS fallback, shall operate in CS/PS mode 1 or CS/PS mode 2.”
也就是说UE如果配置使用了CS fallback这个特性或者没有配置CS fallback但激活了SMS over SGs特性,那就应该工作在CS/PS mode 1或CS/PS mode 2。因此,据我猜想,手机上应该有设置可以激活CS fallback或者SMS over SGs。
发表于 2013-3-12 10:09:48 |只看该作者
iphone5(港行定制)上没找到,每次都是combined。如果SGs不通,也决不放弃,坚决combined到死~~
发表于 2013-3-18 10:13:00 |只看该作者
也就是说,发起不发起联合扶着,完全取决于UE
发表于 2013-3-18 11:44:05 |只看该作者
应该是吧,android上也没找到相关设置。也是开机就combined,不成功就不断尝试attach。
版主 特殊贡献奖
发表于 2013-3-18 15:22:41 |只看该作者
因为LTE要走语音,如果当前没有IMS的方式,那只有CSFallback走SGs interface。所以干脆手机上就做死了吧。不然没办法语音了。只能成功,不能失败。
发表于 2013-7-16 13:14:12 |只看该作者
目前手机发起的都是combine attach,但是如果MME和MSC之间的update location失败的话,MME应该回给UE的attach accept类型是EPS only,这样UE就不能收发短信和接打电话了。
发表于 2014-3-6 11:35:07 |只看该作者
也就是说,终端能决定是否做combine attach,感觉终端应该灵活一点,虽然写死程序对可靠性有点帮助,但是灵活一点可提高用户可用性,个人观点
GMT+8, 2025-11-24 08:11 , Processed in 0.026027 second(s), 14 queries .
