查看: 6961|回复: 0
Diameter 接口规范list   [复制链接]
版主 特殊贡献奖
发表于 2013-1-16 10:23:48 |只看该作者 |倒序浏览
The complete list of interfaces supported by the SDC is available in the table below. The solution is compliant with 3GPP Releases 7,8, 9, 10 and 11.
Interface        Network Location        Supported version
Diameter Base Protocol                IETF RFC 3588, 4960, 793
Diameter Commands for 3GPP                IETF RFC 3589
Diameter Credit Control App                IETF RFC 4006
NASREQ Support for Network Access Server                IETF RFC 4005
EAP Support for Extensible Authentication Protocol                IETF RFC 4072
Mobile IPv4 Support for Diameter Mobile IPv4                IETF RFC 4004
Diameter Mobile IPv6                IETF RFC 5447
Diameter SIP Application                IETF RFC 4740
Sh interface        Between AS and HSS        3GPP TS 29.328 & TS 29.329
Sd interface        Between PCRF and TDF (Traffic Detection Function)        3GPP TS 29.212
Sy interface        Between PCRF and OCS/OFCS, Policy and Charging Control over Sy reference point        3GPP TS 29.219
Dh interface        Between AS and SLF        3GPP TS 29.328 & TS 29.329
Rf interface        Between AS and OFCS        RFC 4006, 3GPP TS 32.225 & TS 32.299
Ro interface        Between AS and OCS        RFC 4006, 3GPP TS 32.225 & TS 32.299
Re interface        Between OCF and Rating function        3GPP TS 32.296
Cx interface        Between CSCF and HSS        3GPP TS 29.228 & TS29.229
Dx interface        Between CSCF and SLF        3GPP TS 29.228 & TS29.229
Sp interface        Between PCRF and SPR        3GPP TS 23.203, TS 29.328 & TS 29.329
Rx interface        Between AF and the PCRF        3GPP TS 23.203 & TS 29.214
Gx interface        Between PCEF and the PCRF        3GPP TS 29.212 & TS 23.203
Gy interface        Between OCS and PCEF        3GPP TS 32.29, TS 32.251 & RFC 4006
Gz interface        Between PCEF and OFCS        3GPP TS 32.240, TS 32.295
Gq interface        Between AF and PDF        3GPP TS 29.209
Gi interface        Between Packet Domain and an external packet data network        3GPP TS 29.061
SGi interface        between the EPC based PLMN and the packet data network        3GPP TS 29.061
Zh interface        Between BSF and HSS        3GPP TS 29.109 & TS 33.220
Zh interface        Between BSF and HSS (used between operators)        3GPP TS 29.109 & TS 33.220
Dz interface        Between BSF and SLF        3GPP TS 29.109 & TS 33.220
Zn interface        Between BSF and NAF        3GPP TS 29.109 & TS 33.220
Zn’ interface        Between BSF and Zn Proxy        3GPP TS 29.109 & TS 33.220
Dw interface        Between the 3GPP AAA Server and an SLF        3GPP TS 29.234
Wa interface        Between the WLAN AN and the 3GPP AAA Proxy        3GPP TS 29.234
Wd interface        Between the 3GPP AAA Proxy and 3GPP AAA Server        3GPP TS 29.234
Wx interface        Between the 3GPP AAA Server and the HSS        3GPP TS 29.234
Wm interface        Between the 3GPP AAA Server and the PDG        3GPP TS 29.234
Wg interface        Between the 3GPP AAA Server/Proxy and the WAG        3GPP TS 29.234
Pr interface        Between the 3GPP AAA Server and the PNA        3GPP TS 29.234
Gmb interface        Between GGSN and BM-SC        3GPP TS 29.061
Mz interface        Mz is the roaming variant of the Gmb reference point with the same functionality        3GPP TS 29.061
Bi interface        CCF to BS        3GPP TS TS 32.225
MM10 interface        Multimedia Messaging Service (MMS)        OMA MM10 interface
Ty interface        Between AGW and PCRF        3GPP2 TSG-X X.S0013-014
Tx interface        Between AF and PCRF        3GPP2 TSG-X X.S0013-013
S6a interface        Between MME and HSS        3GPP TS 29.272
S6b interface        Between the 3GPP AAA Server/Proxy and the PDN GW        3GPP TS 23402
S6d interface        Between MME and HSS        3GPP TS 29.272
S7c interface        Transfer of (QoS) policy information from PCRF to the S-GW.        3GPP TS 32820, TS 23402
S9 interface        Between PCRF in the HPLMN (H PCRF) and a PCRF in the VPLMN (V PCRF)        3GPP TS 23.203 & TS 29.215
S13 interface        Between MME and EIR        3GPP TS 29.272
Gxa interface        PCRF and the BBERF        3GPP TS 23.203
Gxb interface        Between ePDG and vPCRF        3GPP TS 23.203
Gxc interface        PCRF and the BBERF        3GPP TS 23.203
SWa interface        Between an un-trusted non-3GPP IP access and the 3GPP AAA Server/Proxy        3GPP TS 23402
SWd interface        Between the 3GPP AAA Proxy and 3GPP AAA Server        3GPP TS 23402
SWn interface        Between Untrusted Non-3GPP IP Access and ePDG        3GPP TS 23402
SWm interface        Between the 3GPP AAA Server/Proxy and the ePDG        3GPP TS 23402
SWx interface        Between the 3GPP AAA Server and the HSS        3GPP TS 23402
Sta interface        Between a trusted non-3GPP IP access and the 3GPP AAA Server/Proxy        3GPP TS 23402
H2 interface        Between the 3GPP AAA Server and the HA        3GPP TS 23402
Gq’ interface        Between AF and RACS        ETSI TS 183.017
E2 interface        Between AF and NASS        ETSI TS 283 035
E4 interface        Between NASS and RACS        ETSI TS 283 034
E5 interface        Between UAAF – UAAF        ETSI TS 282 004
Re interface        Between RCEF and RACS        ETSI TS 183 060
A3 interface        Between UAAF and AMF        ETSI TS 282 004
A4 interface        Between CLF and UAAF        ETSI TS 282 004
Rr interface        x-RACF        03196-NGN-R3
Zh interface        Generic Authentication Architecture (GAA)        PKT-SP-29.109
Zn interface        Generic Authentication Architecture (GAA)        PKT-SP-29.109
Cx interface        CSCF- HSS        PKT-SP-29.229
Dx interface        CSCF- SLF        PKT-SP-29.229
Pkt-laes-2 interface        Session Control Element — DF (electronic surveillance requirements)        PKT-SP-ES-INF-I01
P-CSCF- PAM Interface        Between P-CSCF – PAM        PKT-SP-QOS-I02-080425, 3GPP TS 23.203 & TS 29.214
Pkt-mm-2 interface        Policy Server — CMTS        3GPP TS 29.212 & TS 23.203
TC-6        Based on 3GPP Rx        MSF-IA-DIAMETER.010-FINAL
TC-7        Based on 3GPP Ty        MSF-IA-DIAMETER.014-FINAL
TC-8        Based on 3GPP Tx        MSF-IA-DIAMETER.013-FINAL
TC-9        Based on 3GPP Rq        MSF-IA-DIAMETER.005-FINAL
TC-10        Based on 3GPP Gx        MSF-IA-DIAMETER.012-FINAL
TC-11        Based on 3GPP e4        MSF-OA-DIMATER.011-FINAL
DB-0        Based on 3GPP Cx/Dx        MSF-IA-DIAMETER.006-FINAL
DB-2        Based on 3GPP Sh/Dh        MSF-IA-DIAMETER.003-FINAL
BI-1        Based on 3GPP Rf        MSF-IA-BILLING.001-FINAL
LOC-1        Based on 3GPP e2        MSF-IA.DIAMETER.008-FINAL
Rw interface        Between the Policy Decision Physical Entity (PD-PE) and the Policy Enforcement Physical Entity (PE-PE)        ITU Q.3303.3
Rs interface        Between Service Control Physical Entity (SC-PE) and Resource and Admission Control Physical Entity (RAC-PE)        ITU Q.3301
GMT+8, 2025-11-24 10:02 , Processed in 0.023030 second(s), 12 queries .
