Sequence Number: This field is an optional field in G -PDUs. It is used as a transaction identity for signalling messages having a response message defined for a request message, that is the Sequence Number value is copied from the request to the response message header. In the user plane, an increasing sequence number for T-PDUs is transmitted via GTP-U tunnels, when transmission order must be preserved.
GTP消息头中,用户面数据消息流水号是可选的,但是控制面消息中流水号作为事务标识,是否是必选?如果非必选,因为用户面消息TEID是唯一的,而控制面消息的TEID对于同一个用户的不同上下文来说是一样的,如何来关联上下行消息对? 另外,控制面和用户面的IP地址是否是唯一的,或者同一个用户的不同PDP上下文可以共用一个SGSN/GGSN的地址? 期待答复~~
