查看: 4220|回复: 3
sgsn对于RA-capability-update消息的查找范围 [复制链接]
Rank: 1
发表于 2012-9-18 09:00:42 |只看该作者 |倒序浏览
小弟近日遇到如下问题:
场景如下:
终端进行InterRAU,从SGSN1路由到SGSN2,sgsn1和sgsn2属于不同厂商,不同的SGSN Pool。
此时,从Gb信令看,SGSN2首先收到的是RA-capability-update消息。并且回应RA-capability-update-ack消息,随后进行路由更新流程。、
想了解下,这种情况下,SGSN2对于RA-CAP的能查到终端能力吗?即sgsn2会不会向sgsn1查询,会的话通过什么消息传递?sgsn对于RA-CAP的消息查询范围是多少?
发表于 2012-9-18 22:14:06 |只看该作者
MS在进入SGSN2的路由区后会发送RAU Request消息给SGSN2,该消息中就包含了MS Radio Access capability。所以SGSN2不用去向SGSN1去要,MS就直接告诉它了。然后如果BSC通过Radio Access Capability Update消息向SGSN2请求终端能力时,SGSN2将通过RA-CAPABILITY-UPDATE-ACK PDU 并包含MS的终端能力返回给BSC。
“The BSS may request an MS's current Radio Access capability and/or its IMSI by sending to an SGSN a RA CAPABILITY-UPDATE PDU which includes the TLLI of the MS and a Tag. The allocation of the Tag is implementation specific. The BSS then starts timer T5.
The SGSN shall respond by sending a RA-CAPABILITY-UPDATE-ACK PDU which includes the TLLI of the MS, the Tag received in the corresponding RA-CAPABILITY-UPDATE PDU, and an RA-Cap-UPD-Cause field; the IMSI of the MS is also included when known. The BSS shall stop timer T5.
If the RA-Cap-UPD-Cause is set to "OK", then an MS Radio Access Capability field and the IMSI shall be present. The received MS's radio access capability, if valid, shall then replace any radio access capability previously associated with the MS. If the RA-Cap-UPD-Cause is not set to "OK", then neither the MS Radio Access Capability nor the IMSI shall be present in the RA-CAPABILITY-UPDATE-ACK PDU."
Rank: 1
发表于 2012-9-18 22:50:47 |只看该作者
版主可能误会我的意思了。如果ms进入sgsn后先发送了rau request当然是没有问题的。现在遇到的情况是,ra-cap消息是先于rau request消息上发至sgsn2。完成ra-cap流程后,终端才上发rau request消息,这种情况下,对于ra-cap消息sgsn2会是如何处理。
我一直觉得sgsn2是应该找不到这个ms的,ra-cap消息回送Tlli unknow in sgsn的,但发现存在sgsn2找到终端的情况,但回送的并不是这个的终端能力,于是之后这些终端路由更新都发生了失败。所以我怀疑是不是sgsn2查找ra-cap的时候出了问题。想知道对于ra-cap消息,sgsn的查找范围
发表于 2013-8-26 00:12:47 |只看该作者
想了解一下,进入新的SGSN没有进行RAU,而是先RA-capability-update。之后有伴随之后PDP激活无响应的的情况吗?
GMT+8, 2025-11-24 05:31 , Processed in 0.023103 second(s), 12 queries .
