查看: 4424|回复: 0
问:MOCN配置下RAU时向old SGSN获取上下文失败时的处理方式 [复制链接]
义 超级之星 勤 论坛核心会员
发表于 2012-9-11 15:25:35 |只看该作者 |倒序浏览
之前看到爱总在其他一个帖子里提到的:
如果是RAU的话,获取context失败时会以CC9拒绝RAU,终端收到CC9会删除P-TMSI而发起IMSI附着。但对于P-TMSI附着的话则可能不会回CC9而起发起identification procedure向MS获取。
但在MCON时,我看到alex文档中有下面的描述:
In the MOCN constellation, when the UE  performs a Routing Area Update (RAU), if an invalid NRI, which means the P-TMSI is wrong, is included in RAURequest message due to defects of some mobile terminals, the RNC may select the wrong  SGSN . If the query fails (this includes an external DNS-server query, local RAI-table query, or local NRI-table query, depending on the operator's configuration) or there is no Gn/Gp interface between the new and old  SGSN , the new SGSN cannot get the Mobility Management and  PDP  contexts from the old  SGSN. The new SGSN will then fetch the IMSI from the UE by means of an identification procedure(当无法从老的SGSN获得MM和PDP上下文的话,会通过identification流程向UE获取...). The RAU  Request message together with the IMSI is then redirected to the correct SGSN  by the  RNC .
    Fetching  IMSI over the air is an enhancement to the licensed  MOCN feature. It can be turned on or off using the function parameter fetch_imsi_no_gp by the CLI  command modify_node_function. For more details, see Parameter Description and Feature Management (CLI).
为什么MCON时即使RAU获取上下文失败也不会拒绝而是UE获取呢?
并且为何说“Fetching IMSI over the air is an enhancement to the licensed  MOCN feature”,获取IMSI不是正常的流程吗?即使不在MCON的情况下?
谢谢
欢迎多多交流
PS CORE & SS7 & SIGTRAN & IP
有相关的专业技术网站/Q群也多谢推荐
GMT+8, 2025-12-19 09:10 , Processed in 0.022755 second(s), 12 queries .
