查看: 2993|回复: 0
User-Equipment-Info AVP [复制链接]
发表于 2012-8-22 16:26:53 |只看该作者 |倒序浏览
User-Equipment-Info AVP携带的主要是手机用户的IMEI信息,通过用户的IMEI,可以判别用户终端的手机类型从而可以实现更多灵活的操作。在RFC4006中关于该AVP的原文定义如下:
“The User-Equipment-Info AVP (AVP Code 458) is of type Grouped and allows the credit-control client to indicate the identity and capability of the terminal the subscriber is using for the connection to network.
It is defined as follows (per the grouped-avp-def of RFC 3588 [DIAMBASE]):
User-Equipment-Info ::= < AVP Header: 458 >
                              { User-Equipment-Info-Type }
                              { User-Equipment-Info-Value }”
该AVP由两部分组成,User-Equipment-Info-Type以及User-Equipment-Info-Value。Type里面指明了用户信息的类型,如果取值为0则代表IMEISV,则后续及User-Equipment-Info-Value部分携带的就是用户的IMEI。
参见一个实际报文的该AVP截图。
GMT+8, 2025-11-24 11:46 , Processed in 0.023943 second(s), 13 queries .
