查看: 4597|回复: 1
MM上下文中的一些参数求解 [复制链接]
Rank: 3Rank: 3Rank: 3
发表于 2011-8-7 17:02:19 |只看该作者 |倒序浏览
在看MM上下文中信息的时候碰到这些玩意,不知道到底范围有多大,区别在哪里,请教各位前辈。小弟问题比较多,请理解
Routeing Area
Current routeing area.
Cell Identity
Current cell in READY state, last known cell in STANDBY or IDLE state.
Cell Identity Age
Time elapsed since the last LLC PDU was received from the MS at the SGSN.
Service Area Code
Last known SAC when initial UE message was received or Location Reporting procedure was executed.
Service Area Code Age
Time elapsed since the last SAC was received at the 3G‑SGSN.
还有位置区
KSI
Key Set Identifier.
GPRS‑CSI
Optional GPRS CAMEL subscription information, see 3GPP TS 23.016
ODB for PS parameters
Indicates that the status of the operator determined barring for packet oriented services.
请高人讲解一下这些参数代表什么意思,谢谢!
发表于 2011-8-15 20:58:56 |只看该作者
回复 zglaojiang 的帖子
  我不确定我理解了你的问题没有啊。所以先试着答复一下。
  SA是一个SGSN的服务范围,由若干个RA组成。RA又由若干个Cell小区组成。是包含的关系。多个SA就组成了一个PLMN的服务范围。
  根据TS24.008的规范,CK and IK form a Key Set Identifier (KSI) (see 3GPP TS 33.102 [5a]) which is encoded the same as the CKSN and is therefore included in the CKSN field,并且In some specifications the term KSI (Key Set Identifier) might be used instead of the term ciphering key sequence number.所以KSI就是CK+IK即CKSN用于鉴权的参数。具体的话可以参考用户鉴权过程。GPRS‑CSI可以不用关心,是用于和智能网相关的签约参数,用于预付费用户的一些控制。但现网Ge接口并没有开,所以这个
参数不用管(虽然比较功利)。但不代表预付费用户没有控制,有,但不通过Ge接口做。可以通过GGSN后面的Gy接口来做。最后是ODB,operator determined barring。代表的是运营商对用户的一种人工干预手段。能够切断非法用户,保护自己的网络。例如当用户欠费、违反签约协议等、或者中了病毒乱发包等等。运营商都可以采用这种方式将用户踢掉。对应的有一个专门的PDP上下文去激活的cause code为#8。
GMT+8, 2024-9-27 23:13 , Processed in 0.079267 second(s), 12 queries .
