谁有Gb口gsm_a.dtap_msg_sm_type == 0x4a和gsm_a.dtap_msg_gmm_type == 0x4a的数据包
xiaoxiaoh16
2011-10-20 16:19:28
hi,
大家好,谁有Gb口gsm_a.dtap_msg_sm_type == 0x4a和gsm_a.dtap_msg_gmm_type == 0x4a的数据包,最好都是带imsi号的,最近需要这种类型的数据包,看着协议构造太难了,小菜鸟先在这里谢谢了!
爱卫生
2011-10-20 21:32:50
回复
xiaoxiaoh16
的帖子
我手上没有,但我把你的需求翻译一下,看大家有没有哦。不过gmm_type好像没有0x4a这个值哦!
如下:
const value_string gsm_a_dtap_msg_gmm_strings[] = {
{ 0x01, "Attach Request" },
{ 0x02, "Attach Accept" },
{ 0x03, "Attach Complete" },
{ 0x04, "Attach Reject" },
{ 0x05, "Detach Request" },
{ 0x06, "Detach Accept" },
{ 0x08, "Routing Area Update Request" },
{ 0x09, "Routing Area Update Accept" },
{ 0x0a, "Routing Area Update Complete" },
{ 0x0b, "Routing Area Update Reject" },
{ 0x0c, "Service Request" },
{ 0x0d, "Service Accept" },
{ 0x0e, "Service Reject" },
{ 0x10, "P-TMSI Reallocation Command" },
{ 0x11, "P-TMSI Reallocation Complete" },
{ 0x12, "Authentication and Ciphering Req" },
{ 0x13, "Authentication and Ciphering Resp" },
{ 0x14, "Authentication and Ciphering Rej" },
{ 0x1c, "Authentication and Ciphering Failure" },
{ 0x15, "Identity Request" },
{ 0x16, "Identity Response" },
{ 0x20, "GMM Status" },
{ 0x21, "GMM Information" },
{ 0, NULL }
const value_string gsm_a_dtap_msg_sm_strings[] = {
{ 0x41, "Activate PDP Context Request" },
{ 0x42, "Activate PDP Context Accept" },
{ 0x43, "Activate PDP Context Reject" },
{ 0x44, "Request PDP Context Activation" },
{ 0x45, "Request PDP Context Activation rej." },
{ 0x46, "Deactivate PDP Context Request" },
{ 0x47, "Deactivate PDP Context Accept" },
{ 0x48, "Modify PDP Context Request(Network to MS direction)" },
{ 0x49, "Modify PDP Context Accept (MS to network direction)" },
{ 0x4a, "Modify PDP Context Request(MS to network direction
{ 0x4b, "Modify PDP Context Accept (Network to MS direction)" },
{ 0x4c, "Modify PDP Context Reject" },
{ 0x4d, "Activate Secondary PDP Context Request" },
{ 0x4e, "Activate Secondary PDP Context Accept" },
{ 0x4f, "Activate Secondary PDP Context Reject" },
{ 0x50, "Reserved: was allocated in earlier phases of the protocol" },
{ 0x51, "Reserved: was allocated in earlier phases of the protocol" },
{ 0x52, "Reserved: was allocated in earlier phases of the protocol" },
{ 0x53, "Reserved: was allocated in earlier phases of the protocol" },
{ 0x54, "Reserved: was allocated in earlier phases of the protocol" },
{ 0x55, "SM Status" },
{ 0x56, "Activate MBMS Context Request" },
{ 0x57, "Activate MBMS Context Accept" },
{ 0x58, "Activate MBMS Context Reject" },
{ 0x59, "Request MBMS Context Activation" },
{ 0x5a, "Request MBMS Context Activation Reject" },
{ 0x5b, "Request Secondary PDP Context Activation" },
{ 0x5c, "Request Secondary PDP Context Activation Reject" },
{ 0x5d, "Notification" },
xiaoxiaoh16
2011-10-21 15:22:17
首先谢谢爱总百忙中回帖啊,呵呵,我还想问一个问题,在Gb口:imsi对能唯一定位一个用户吗?那用tlli呢?如果tlli自己不能,tlli+bsc呢?bsc在用户数据包中有体现字段吗?
爱卫生
2011-10-22 17:23:40
回复
xiaoxiaoh16
的帖子
并不是所有的MS-SGSN的GMM消息里都有IMSI信息啊。但TLLI肯定是有的。而TLLI是由P-TMSI派生出来的。所以用TLLI就可以来定位用户了。如果只是想定位一个用户的话,那就TLLI就可以了,和BSC无关了。BSC在Gb口通过NSEI来标识的,在包中可以通过查看对应的BVCI来看连接到哪个BSC。
z36306610
2011-10-25 10:08:09
0x4a, "Modify PDP Context Request(MS to network direction)"这个在网络中好像很难发生,绝大部分为{ 0x48, "Modify PDP Context Request(Network to MS direction)" },主要在用户3G到2G重选过程中RAU之后会有modify的过程,对QoS进行修改,主要修改3个参数Peak throughput 、Maximum bitrate for uplink和Maximum bitrate for downlink,这是从联通现网中采集的数据分析的。
xiaoxiaoh16
2011-10-25 15:27:55
回复
z36306610
的帖子
嗯嗯,是啊,我在一个很大的文件中过滤到了一个这样的包,可是太悲催了,竟然是不带imsi号的情况。
xiaoxiaoh16
2011-10-25 15:30:10
回复
爱卫生
的帖子
太谢谢爱总了,恩,我根据tlli过滤到了一个用户的数据包,这个是我要找到的一种情况,另一种带有imsi号的这类数据包没有找到,我再仔细看看协议,看看不能自己这类数据包,再次感谢!
z36306610
2011-10-26 16:10:35
用专业工具找的话很简单,呵呵!
xiaoxiaoh16
2011-10-26 18:03:44
回复
z36306610
的帖子
我构造了一个不知道对不对呢
xiaoxiaoh16
2011-10-26 18:12:38
根据现有数据包构造了一个,由于涉及到可选字段等,不知道构造的对不对,专家们帮我指导下吧,万分感谢~
爱卫生
2011-10-29 17:06:42
回复
xiaoxiaoh16
的帖子
我感觉构建的IMSI应该没有问题吧。就是GMM消息modify pdp context request有3个必选IE,在TS24008里定义。包括Protocol discriminator、Transaction identifier、Message type。好像缺一个Transaction identifier。另外通常这个消息是用来更新Qos的,所以通常都会有一个Requested Qos和TFT。不过这两个是可选的。
