[attach]826[/attach]
首先,PCRF根据UE应用层所需要的QoS信息,生成相应的QoS准则,通过基于Diameter的RAR(Re-Authentication Request)命令发送给PGW。
PGW根据相应的QoS准则来配置EPS Bearer的QoS,并发送Create Bearer Request 消息给SGW, SGW将相应的消息转发给MME, SGW与MME之间的信息示例如下:
GPRS Tunneling Protocol V2
Flags: 72
010. .... = Version: 2
.... 1... = T: 1
Message Type: Create Bearer Request (95)
Message Length: 743
Tunnel Endpoint Identifier: 3300033 (MME的GTP -C的TEID 值)
Sequence Number: 0
Spare: 256
Linked EPS Bearer ID (LBI) :
IE Type: EPS Bearer ID (EBI) (73)
IE Length: 1
000. .... = CR flag: 0
.... 0000 = Instance: 0
.... 0101 = EPS Bearer ID (EBI): 5
Bearer Context : [Grouped IE]
IE Type: Bearer Context (93)
IE Length: 69
EPS Bearer ID (EBI) :
IE Length: 1
.... 0000 = EPS Bearer ID (EBI): 0 (EBI是由MME分配的,由于此时并没有分配,所以设置为零)
Fully Qualified Tunnel Endpoint Identifier (F-TEID) :
IE Type: Fully Qualified Tunnel Endpoint Identifier (F-TEID) (87)
IE Length: 9
1... .... = V4 (True-IPV4 address field Exists,False-Doesn't Exist in F-TEID): True
.0.. .... = V6 (True-IPV6 address field Exists,False-Doesn't Exist in F-TEID): False
...0 0001 = Interface Type: S1-U SGW GTP-U interface (1)
TEID/GRE Key: 34
F-TEID IPv4: 30.0.2.1 (30.0.2.1)
IE Length: 9
.... 0001 = Instance: 1
...0 0101 = Interface Type: S5/S8 PGW GTP-U interface (5)
TEID/GRE Key: 34
F-TEID IPv4: 20.0.0.1 (20.0.0.1)
EPS Bearer Level Traffic Flow Template (Bearer TFT) :
IE Type: EPS Bearer Level Traffic Flow Template (Bearer TFT) (84)
IE Length: 8
001. .... = Operation Code: Create New TFT (1)
.... 0001 = Number of Packet Filters: 1
...0 .... = Ebit: False
Packet Filter 1
.... 0000 = Packet Filter Identifier: 0
..11 .... = Direction: bidirectional (3) (上行和下行双向的Filter)
Evaluation Precedence: 0
Length of Packet Filter: 3
Component Type: Single remote port type (80)
Single remote port type: 80
Bearer Level Quality of Service (Bearer QoS) :
IE Type: Bearer Level Quality of Service (Bearer QoS) (80)
IE Length: 22
.... ...1 = PVI (Pre-emption Vulnerability): True
..00 00.. = PL (Priority Level): 0
.0.. .... = PCI (Pre-emption Capability): False (PVI,PL,以及是ARP的属性,具体内容参见3GPP 23.401)
Label (QCI): 9
Maximum Bit Rate For Uplink: 65535000
Maximum Bit Rate For Downlink: 65535000
Guaranteed Bit Rate For Uplink: 65535000
Guaranteed Bit Rate For Downlink: 65535000
MME为每个EPS Bearer分配相应的EBI (EPS Bearer ID),构造相应的 Activate Dedicated EPS Bear消息,将其作为NAS PDU,包含在发送到eNodeB的Bear Setup Request 消息中。
eNodeB将EPS Bearer的QoS映射到空口上的QoS,然后通过向UE发送RRCConnectionReconfiguration消息来建立相应的DRB,并对DRB进行PDCP层,逻辑层,以及RLC层等进行配置。在消息中还作为NAS PDU传输来自MME的Activate Dedicated EPS Bear。在NAS PDU中,LBI (Linked EPS Bear ID)给出了与Dedicated EPS Bearer对应的Default EPS Bear的标识, TFT表示应用到UE的上行TFT,其中的Precedence指出了Packet Filter的优先级,数值越低,表示优先级越高。UE在发送上行数据包的时候,按照Packet Filter的优先级对数据包进行匹配,如果匹配成功, UE就会在相应的EPS Bearer(Radio Bearer)上发送数据,否则的话, UE会在缺省的EPS Bearer上发送数据。
+-Rrc
| \-Dcch [Union]
| +-message_
| \-c1 [Union]
| \-rrcConnectionReconfiguration [Union]
| +-rrc_TransactionIdentifier=0 [INTEGER]
| +-criticalExtensions
| \-c1 [Union]
| \-rrcConnectionReconfiguration_r8 [Union]
| +-measConfig=omit
| +-mobilityControlInfo=omit
| +-dedicatedInfoNASList=omit
| +-radioResourceConfigDedicated
| | +-srb_ToAddModList=omit
| | +-drb_ToAddModList [RecordOf]
| | | [0]
| | | +-eps_BearerIdentity=6 [INTEGER]
| | | +-drb_Identity=2 [INTEGER]
| | | +-pdcp_Config
| | | | +-discardTimer=infinity_ [ENUM]
| | | | +-rlc_AM
| | | | | +-statusReportRequired=true [BOOLEAN]
| | | | +-rlc_UM=omit
| | | | +-headerCompression
| | | | \-notUsed [Union]=NULL
| | | +-rlc_Config
| | | | \-am [Union]
| | | | +-ul_AM_RLC
| | | | | +-t_PollRetransmit=ms80 [ENUM]
| | | | | +-pollPDU=p128 [ENUM]
| | | | | +-pollByte=kB125 [ENUM]
| | | | | +-maxRetxThreshold=t4 [ENUM]
| | | | +-dl_AM_RLC
| | | | +-t_Reordering=ms80 [ENUM]
| | | | +-t_StatusProhibit=ms60 [ENUM]
| | | +-logicalChannelIdentity=4 [INTEGER]
| | | +-logicalChannelConfig
| | | +-ul_SpecificParameters
| | | +-priority=13 [INTEGER]
| | | +-prioritisedBitRate=infinity_ [ENUM]
| | | +-bucketSizeDuration=ms100 [ENUM]
| | | +-logicalChannelGroup=2 [INTEGER]
| | +-drb_ToReleaseList=omit
| | +-mac_MainConfig=omit
| | +-sps_Config=omit
| | +-physicalConfigDedicated=omit
| +-securityConfigHO=omit
| +-nonCriticalExtension=omit
+-Nas [RecordOf]
[0]
+-SecurityProtection
| +-Status='0010'B [BITSTRING]
+-Pdu
+-Msg
| \-aCTIVATE_DEDICATED_EPS_BEARER_CONTEXT_REQUEST [Union]
| +-epsBearerId='6'H [HEXSTRING]
| +-protocolDiscriminator='0010'B [BITSTRING]
| +-procedureTransactionIdentifier='00'O [OCTETSTRING]
| +-messageType='11000101'B [BITSTRING]
| +-spareHalfOctet='0'H [HEXSTRING]
| +-linkedEpsBearerId
| | +-idValue='0101'B [BITSTRING]
| +-epsQos
| | +-iei=omit
| | +-iel='09'O [OCTETSTRING]
| | +-qci='00000100'B [BITSTRING]
| | +-maxBitRateUl='01101000'B [BITSTRING]
| | +-maxBitRateDl='01101000'B [BITSTRING]
| | +-guaranteedBitRateUl='01001000'B [BITSTRING]
| | +-guaranteedBitRateDl='01001000'B [BITSTRING]
| | +-maxBitRateUlExt='00000000'B [BITSTRING]
| | +-maxBitRateDlExt='00000000'B [BITSTRING]
| | +-guaranteedBitRateUlExt='00000000'B [BITSTRING]
| | +-guaranteedBitRateDlExt='00000000'B [BITSTRING]
| +-tft
| | +-iei=omit
| | +-iel='23'O [OCTETSTRING]
| | +-tftOperationCode='001'B [BITSTRING] 表示创建TFT
| | +-eBit='0'B [BITSTRING]
| | +-noOfPktFilter='0010'B [BITSTRING]
| | +-packetFilterList [RecordOf]
| | | [0]
| | | | +-iei='10'O [OCTETSTRING] 其中可以表示Filter的方向。
| | | | +-precendence='00000000'B [BITSTRING]
| | | | +-iel='0E'O [OCTETSTRING] IPV4 remote Address type (具体内容参见10.5.162/3GPP 24.008)
| | | | +-contents='10C0A80101FFFFFFFF5079B83011'O [OCTETSTRING]
| | | [1]
| | | +-iei='20'O [OCTETSTRING]
| | | +-precendence='00000001'B [BITSTRING]
| | | +-contents='10C0A80101FFFFFFFF50EE483011'O [OCTETSTRING]
| | +-parameterList=omit
| +-transactionIdentifier=omit
| +-negotiatedQos=omit
| +-negotiatedLlcSapi=omit
| +-radioPriority=omit
| +-packetFlowIdentifier=omit
| +-protocolConfigurationOptions=omit
+-PiggybackedPduList=omit
UE存贮得到的相应QoS信息, 并作相应的处理, 然后向eNodeB回应RRCConnectionReconfiguration Complete消息。eNodeB接收到UE的回应后, 回复给MME Bear Setup Response消息。
UE NAS层同时会构造Activate Dedicated EPS Bearer Context Complete消息,并将其作为NAS PDU通过UL Info Transfer发送给eNodeB, eNodeB将此NAS PDU 透传给MME。MME接收到后,生成 Create Bearer Response 消息, 发送给SGW和PGW。
Flags: 72
.... 1... = T: 1
Message Type: Create Bearer Response (96)
Message Length: 424
Tunnel Endpoint Identifier: 1
Sequence Number: 0
Spare: 256
Cause :
IE Type: Cause (2)
IE Length: 2
Cause: Request accepted (16)
.... ...0 = Cause Source (CS: True-Error originated by remote node, False-Error originated by Node sending the Message): False
IE Length: 37
Cause :
IE Type: Cause (2)
IE Length: 2
IE Length: 1
.... 0110 = EPS Bearer ID (EBI): 6
IE Length: 9
...0 0000 = Interface Type: S1-U eNodeB GTP-U interface (0)
TEID/GRE Key: 34
F-TEID IPv4: 30.0.0.1 (30.0.0.1)
IE Length: 9
TEID/GRE Key: 34
