标题: 关于Sib1里面的T3212定时器 [打印本页]
作者: imwoohan 时间: 2014-10-20 16:34:45 标题: 关于Sib1里面的T3212定时器
请问LTE当中,SIB1消息里面的T3212定时器跟Location update accpet里面的T3212定时器有什么区别?TS 24008规范里面写的好模糊。9.2.13 Location updating accept
9.2.13.5 Per MS T3212This IE may be sent by the network to provide the MS with a periodic LAU timer that may be different to the broadcast value, e.g. to lengthen the timer.
