| cause value | S1AP cause | Meaning |
Unspecified | Sent for radio network layer cause when none of the specified cause values applies. | |
TX2RELOCOverall Expiry | The timer guarding the handover that takes place over X2 has abnormally expired. | |
Successful Handover | Successful handover. | |
Release due to E-UTRAN generated reason | Release is initiated due to E-UTRAN generated reason. | |
Handover Cancelled | The reason for the action is cancellation of Handover. | |
Partial Handover | Provides a reason for the handover cancellation. The HANDOVER COMMAND message from MME contained E-RABs to Release List IE and the source eNB estimated service continuity for the UE would be better by not proceeding with handover towards this particular target eNB. | |
Handover Failure In Target EPC/eNB Or Target System | The handover failed due to a failure in target EPC/eNB or target system. | |
Handover Target not allowed | Handover to the indicated target cell is not allowed for the UE in question. |
