标题: MsgType=Activate,具体指什么消息? [打印本页]
作者: 望到天那边    时间: 2014-3-31 09:45:36     标题: MsgType=Activate,具体指什么消息?
各位,请教一下,我在排障时想使用某一feature(UE Signaling Control Log),但发现该feature只对以下消息类型有效,layer3的Activate指的是Request PDP Context Activation吗?还是其它?在什么规范里有对layer 3 Msgtype的详细说明?谢谢各位指教。
MsgType
Indicates the type of radio interface layer 3 message that is measured or controlled. The possible values are the following:
作者: 望到天那边    时间: 2014-3-31 10:14:10
在24.008里面看到一些msgtype的介绍:但还是不知道上文中的activate具体泛指哪些。
Table 10.2/3GPP TS 24.008: Message types for Mobility Management
8 7 6 5 4 3 2 1
x x 0 0 - - - - Registration messages:
0 0 0 1 - IMSI DETACH INDICATION
0 0 1 0 - LOCATION UPDATING ACCEPT
0 1 0 0 - LOCATION UPDATING REJECT
1 0 0 0 - LOCATION UPDATING REQUEST
x x 0 1 - - - - Security messages:
0 0 0 1 - AUTHENTICATION REJECT
0 0 1 0 - AUTHENTICATION REQUEST
0 1 0 0 - AUTHENTICATION RESPONSE
1 1 0 0 - AUTHENTICATION FAILURE…………..
1 0 0 0 - IDENTITY REQUEST
1 0 0 1 - IDENTITY RESPONSE
1 0 1 0 - TMSI REALLOCATION COMMAND
1 0 1 1 - TMSI REALLOCATION COMPLETE
x x 1 0 - - - - Connection management messages:
0 0 0 1 - CM SERVICE ACCEPT
0 0 1 0 - CM SERVICE REJECT
0 0 1 1 - CM SERVICE ABORT
0 1 0 0 - CM SERVICE REQUEST
0 1 0 1 - CM SERVICE PROMPT
0 1 1 0 - Reserved (see NOTE)
1 0 0 0 - CM RE-ESTABLISHMENT REQUEST
1 0 0 1 - ABORT
x x 1 1 - - - - Miscellaneous messages:
0 0 0 0 - MM NULL
0 0 0 1 - MM STATUS
0 0 1 0 - MM INFORMATION
Table 10.3/3GPP TS 24.008: Message types for Call Control and call related SS messages
8 7 6 5 4 3 2 1
x x 0 0 0 0 0 0 escape to nationally specific
message types; see 1) below
x x 0 0 - - - - Call establishment messages:
0 0 0 1 - ALERTING
1 0 0 0 - CALL CONFIRMED
0 0 1 0 - CALL PROCEEDING
0 1 1 1 - CONNECT
1 1 1 1 - CONNECT ACKNOWLEDGE
1 1 1 0 - EMERGENCY SETUP
0 0 1 1 - PROGRESS
0 1 0 0 - CC-ESTABLISHMENT
0 1 1 0 - CC-ESTABLISHMENT CONFIRMED
1 0 1 1 - RECALL
1 0 0 1 - START CC
0 1 0 1 - SETUP
x x 0 1 - - - - Call information phase messages:
0 1 1 1 - MODIFY
1 1 1 1 - MODIFY COMPLETE
0 0 1 1 - MODIFY REJECT
0 0 0 0 - USER INFORMATION
1 0 0 0 - HOLD
1 0 0 1 - HOLD ACKNOWLEDGE
1 0 1 0 - HOLD REJECT
1 1 0 0 - RETRIEVE
1 1 0 1 - RETRIEVE ACKNOWLEDGE
1 1 1 0 - RETRIEVE REJECT
x x 1 0 - - - - Call clearing messages:
0 1 0 1 - DISCONNECT
1 1 0 1 - RELEASE
1 0 1 0 - RELEASE COMPLETE
1 0 0 1 - CONGESTION CONTROL
1 1 1 0 - NOTIFY
1 1 0 1 - STATUS
0 1 0 0 - STATUS ENQUIRY
0 1 0 1 - START DTMF
0 0 0 1 - STOP DTMF
0 0 1 0 - STOP DTMF ACKNOWLEDGE
0 1 1 0 - START DTMF ACKNOWLEDGE
0 1 1 1 - START DTMF REJECT
1 0 1 0 - FACILITY
Table 10.4/3GPP TS 24.008: Message types for GPRS mobility management
Bits
8 7 6 5 4 3 2 1
0 0 - - - - - - Mobility management messages
0 0 0 0 0 0 0 1 Attach request
0 0 0 0 0 0 1 0 Attach accept
0 0 0 0 0 0 1 1 Attach complete
0 0 0 0 0 1 0 0 Attach reject
0 0 0 0 0 1 0 1 Detach request
0 0 0 0 0 1 1 0 Detach accept
0 0 0 0 1 0 0 0 Routing area update request
0 0 0 0 1 0 0 1 Routing area update accept
0 0 0 0 1 0 1 0 Routing area update complete
0 0 0 0 1 0 1 1 Routing area update reject
0 0 0 0 1 1 0 0 Service Request
0 0 0 0 1 1 0 1 Service Accept
0 0 0 0 1 1 1 0 Service Reject
0 0 0 1 0 0 0 0 P-TMSI reallocation command
0 0 0 1 0 0 0 1 P-TMSI reallocation complete
0 0 0 1 0 0 1 0 Authentication and ciphering req
0 0 0 1 0 0 1 1 Authentication and ciphering resp
0 0 0 1 0 1 0 0 Authentication and ciphering rej
0 0 0 1 1 1 0 0 Authentication and ciphering failure
0 0 0 1 0 1 0 1 Identity request
0 0 0 1 0 1 1 0 Identity response
0 0 1 0 0 0 0 0 GMM status
0 0 1 0 0 0 0 1 GMM information
Table 10.4a/3GPP TS 24.008: Message types for GPRS session management
Bits
8 7 6 5 4 3 2 1
0 1 - - - - - - Session management messages
0 1 0 0 0 0 0 1 Activate PDP context request
0 1 0 0 0 0 1 0 Activate PDP context accept
0 1 0 0 0 0 1 1 Activate PDP context reject
0 1 0 0 0 1 0 0 Request PDP context activation
0 1 0 0 0 1 0 1 Request PDP context activation rej.
0 1 0 0 0 1 1 0 Deactivate PDP context request
0 1 0 0 0 1 1 1 Deactivate PDP context accept
0 1 0 0 1 0 0 0 Modify PDP context request(Network to MS direction)
0 1 0 0 1 0 0 1 Modify PDP context accept (MS to network direction)
0 1 0 0 1 0 1 0 Modify PDP context request(MS to network direction)
0 1 0 0 1 0 1 1 Modify PDP context accept (Network to MS direction)
0 1 0 0 1 1 0 0 Modify PDP context reject
0 1 0 0 1 1 0 1 Activate secondary PDP context request
0 1 0 0 1 1 1 0 Activate secondary PDP context accept
0 1 0 0 1 1 1 1 Activate secondary PDP context reject
0 1 0 1 0 0 0 0 Reserved: was allocated in earlier phases of the protocol
0 1 0 1 0 0 0 1 Reserved: was allocated in earlier phases of the protocol
0 1 0 1 0 0 1 0 Reserved: was allocated in earlier phases of the protocol
0 1 0 1 0 0 1 1 Reserved: was allocated in earlier phases of the protocol
0 1 0 1 0 1 0 0 Reserved: was allocated in earlier phases of the protocol
0 1 0 1 0 1 0 1 SM Status
0 1 0 1 0 1 1 0 Activate MBMS Context Request
0 1 0 1 0 1 1 1 Activate MBMS Context Accept
0 1 0 1 1 0 0 0 Activate MBMS Context Reject
0 1 0 1 1 0 0 1 Request MBMS Context Activation
0 1 0 1 1 0 1 0 Request MBMS Context Activation Reject
0 1 0 1 1 0 1 1 Request Secondary PDP Context Activation
0 1 0 1 1 1 0 0 Request Secondary PDP Context Activation Reject
