个人觉得应该是可以的。
在BSSGP的规范里描述paging流程,并且对paging-ps pdu的内容有描述。摘录部分如下:“
The SGSN provides an indication of the cells within which the BSS shall page the MS. The levels of resolution within one BSS are: all cells within the BSS, all cells on the BSS within one location area, all cells on the BSS within one routing area, and one BVCI (i.e. cell). A routing area, a location area, or a BSS area is associated with one or more NSEIs. If the cells in which to page the MS are served by several NSEIs then one paging PDU must be sent to each of these NSEIs.
A paging PDU shall be used to generate the corresponding radio interface paging request message(s) to be transmitted at the appropriate time.”
另外,paging-ps pdu构成如下:
[attach]3050[/attach]
可以看到,附件里的pcap paing报文该带的也都带齐了。
