S1AP和S-TMSI是不同层的东西,一个是NAS层,一个是S1层。所以没有直接关联。S-TMSI是由GUTI派生出来的。所以是随着GUTI的变化而变化的。如果附着过程中(假设MME不变的话),GUTI的值变了,那S-TMSI就变。GUTI没变的话,那S-TMSI就不变。而GUTI在附着过程中可以变也可以不变,规范并没强制,看厂家产品。
是4个字节。你把37773326转换成十六进制是240600E,不包括C0。查了下网上的资料,这个应该是ASN.1的编码的要求,不用管它。都有这个前缀。wireshark官方的bug频道也给出了这个说明。
www.wireshark.org/lists/wireshark-bugs/201001/msg00545.html。
Actually, the length of MME-UE-S1AP-ID is 4 bytes. This byte 30 that is C0 in
other messages is used for ASN.1 coding for the UE-S1AP-ID-pair, which
according to 36.413 is Sequence, so the meaning of that byte would be:
30 ASN.1 format: Universal/Constructed/Sequence
In other messages, where MME-UE-S1AP-ID and ENB-UE-S1AP-ID come separate, not
in this UE-S1AP-ID-pair field, the equivalent byte has a different content:
C0 ASN.1 format: Private/Primitive/...
That´s why they are different. I was wrong to think that 30 is part of the
MME-UE-S1AP-ID. Here is the corrected decoding:
00 Critically - Reject
07 Open Type Length
30 ASN.1 type Universal/Constructed/Sequence <----problem happens here
21 MME-UE-S1AP-ID Byte 1
40 MME-UE-S1AP-ID Byte 2
00 MME-UE-S1AP-ID Byte 3
0F MME-UE-S1AP-ID Byte 4
00 eNB-UE-S1AP-ID Byte 1
02 eNB-UE-S1AP-ID Byte 2
00 02 Cause
