LTE Roaming Guidelines
Table of Contents
1.4 Document Cross-References. 5
2.3.1. SGs Interface for CS Fallback and SMS over SGs. 8
3 Technical Requirements and Recommendations for Interfaces. 8
3.1 General requirements for Inter-PMN interfaces. 8
3.1.1 Inter-PMN IP backbone network requirements. 8
3.1.2 Stream Control Transmission Protocol (SCTP) 8
3.1.3.3 End to End Diameter Architecture. 11
3.1.3.5 Diameter Transport Parameter 13
3.1.3.6 Notification of ME Identity. 13
3.2.1.4 Combined SGW/PGW Selection. 15
3.2.4 PMIP-GTP Interworking. 16
3.3.1 S9 implementation requirements. 16
3.3.2 Guidelines for Diameter interface over S9 interface. 16
4 Technical Requirements and Recommendations for Legacy Interworking and Coexistence 17
4.1 Legacy Interworking scenarios. 17
4.1.2 VPMN has not implemented LTE.. 17
4.1.3 HPMN has not implemented LTE.. 18
4.2 Co-existence scenarios. 19
4.2.2.1 2G/3G Roaming Agreement Only. 19
4.2.2.2 2G/3G and LTE Roaming Agreement 21
4.3.1 Handover to/from 2G/3G and LTE.. 23
4.3.2 Handover to/from non-3GPP accesses and LTE.. 23
5 Technical Requirements and Recommendations for Services. 23
5.1 Short Message Service (SMS) 23
5.2.1.2 Roaming Retry for CSFB procedure. 25
5.2.2 LTE Voice Roaming Architecture. 26
6 Other Technical Requirements and Recommendations. 27
6.1.1 Access Control in the VPMN.. 27
6.1.2 Access Control in the HPMN.. 27
6.1.3 Access Control in the VPMN for CS Fallback. 27
6.2.2 Network Element Addressing. 29
6.2.2.2 Fully Qualified Domain Names (FQDNs) 29
6.3 APN for IMS based services. 29
6.3.2 Definition of the IMS well-known APN.. 30
6.3.4 Disconnect the PDN connection to the IMS APN.. 30
6.4 Emergency PDN connection.. 31
7 Technical Requirements for Dynamic Policy and Charging Control 34
7.1 Home Routed architecture and S8 protocol is GTP.. 34
7.2 Home Routed architecture and S8 protocol is PMIP.. 35
7.3 Local Break Out architecture. 36
Annex A: Testing Framework. 37
Annex B: Diameter Architecture Implementation.. 37
Annex C: Document Management 42
[attach]2751[/attach]
