你是要做Wireshark的包合并对吗?可以用wireshark自带的工具就可以了。
这个工具在C:\Program Files\Wireshark目录下的mergecap.exe文件。你可以运行CLI进入Dos提示符。并将相应的pcap文件也拷贝到这个目录下,然后再执行下述操作。
方法如下:
Merging lots of packet captures into a single PcapSometimes we may wish to merge multiple packet captures i.e. 4-5 100Mb Packet Captures into a single one for analysis and to remove errors such as “Ack received for unknown packet” etc. To do this, (For Windows) – Firstly, copy the packet capture to your “C:\Program files\Wireshark” folder. Then, we can use the “mergecap.exe” program, similar to how editcap works.
C:\Program Files\Wireshark\mergecap.exe -w master-cap.cap subcap1.capsubcap2.cap subcap3.capIn this command, we are merging subcap1 – subcap3 into a few file, called master-cap.cap.
Thats all there is to it. For references, some useful operators are:
