[请教]关于44.018里面CSN.1语法问题
zxr1001
2013-1-2 13:28:03
44.018 10.5.2.37b
关于SI13消息结构的CSN.1描述如下
< SI 13 Rest Octets > ::=
{ L | H
< BCCH_CHANGE_MARK : bit (3) >
< SI_CHANGE_FIELD : bit (4) >
{ 0 | 1 < SI13_CHANGE_MARK : bit (2) >
< GPRS Mobile Allocation : GPRS Mobile Allocation IE > } -- Defined in 3GPP TS 44.060
{ 0 -- PBCCH not present in cell (This shall always be indicated. See sub-clause 1.8) :
< RAC : bit (8) >
< SPGC_CCCH_SUP : bit >
< PRIORITY_ACCESS_THR : bit (3) >
< NETWORK_CONTROL_ORDER : bit (2) >
< GPRS Cell Options : GPRS Cell Options IE > -- Defined in 3GPP TS 44.060
< GPRS Power Control Parameters : GPRS Power Control Parameters IE >
| 1 -- PBCCH present in cell (This shall never be indicated. See sub-clause 1.8) :
< PSI1_REPEAT_PERIOD : bit (4) >
< PBCCH Description : PBCCH Description struct >
{ null | L -- Receiver compatible with earlier release
| H -- Additions in release 99 :
< SGSNR : bit >
| H -- Additions in release Rel-4:
< SI_STATUS_IND : bit >
| H -- Additions in release Rel-6:
{ 0 | 1 < LB_MS_TXPWR_MAX_CCH : bit (5) > }
< SI2n_SUPPORT : bit(2) >
< spare padding > ;
请教其中的H,L是代表什么含义?解码时怎么确定到对应的分支上?
3Q
hycl5410
2013-1-4 10:25:27
看不懂。
也没场景,也不知道是哪个接口,编的是什么。。。
如果能有实例对比着看,估计还靠谱点。
字面理解就是低位和高位,具体怎么回事就完全看不懂了。
