DUs from the old SGSN to the new SGSN at and after an inter-SGSNrouteing area update. In Iu mode, the TEID is also forwarded to the RNC uponRAB assignment and it is used in subsequent tunnelling of user data between theSGSN and the RNC/BSC in order to identify the MS's PDP contexts in the SGSN andthe MS's RAB contexts in the RNC/BSC. It is also used to forward N‑
DUs fromthe SRNC/SBSC to the target RNC/BSC at SRNS/SBSS relocation.| 欢迎光临 51学通信技术论坛 (http://51xuetongxin.com/bbs/) | Powered by Discuz! X2 |
