翻译自《LTE-Signaling&Protocol Analysis [E-UTRAN and UE》一书。该书原版也已上传至论坛城通网盘。
[attach]1857[/attach]
2.1.2.1 Relationship between EMM and ECM
In general, ECM relates to the presence of an S1-bearer plus RRC-connection. As long as both are present, the UE is in ECM-CONNECTED mode. Upon release, the UE switches to ECM-IDLE mode.
Therefore, the UE may well be EMM-registered but still be ECM-idle.
- While the UE is in ECM-CONNECTED state, the network is in charge to control the UE-mobility. While the UE is in ECM-CONNECTED mode, the location of the UE is known with the granularity of a cell inside an eNodeB.
- While the UE is in ECM-IDLE mode, the location of the UE is known with the granularity of a tracking area. Within ECM-IDLE mode, the UE shall perform autonomous cell reselection and tracking area update procedures.
2.1.2.1 EMM和ECM的关系
通常来说,ECM可以看成是存在一个S1的bearer加上一个RRC连接。只要上述两个都存在,UE就处于ECM-CONNECTED模式。一旦释放,UE将切换到ECM-IDLE模式。
因此,UE可能同时处于EMM-registered和ECM-idle状态。
- 当UE处于ECM-CONNECTED状态,网络侧来控制UE的移动性。当UE处于ECM-CONNECTED模式下,网络侧将知道UE位于的当前位置是处在哪个eNB的哪个小区下。
- 当UE处于ECM-IDLE模式,网络侧只知道UE处于哪个TA下。因此在ECM-IDLE模式下,UE应执行小区重选以及TAU流程。
参考:TS36.300(A.2)和,TS23.401(5.1.3.2.2.4)。
挺好~~谢谢分享The location of a UE in ECM-IDLE state is known by thenetwork on a Tracking Area List granularity. A UE in ECM-IDLEstate is paged in all cells of the Tracking Areas in which it is currentlyregistered. The UE may be registered in multiple Tracking Areas. All thetracking areas in a Tracking Area List to which a UE is registered are servedby the same serving MME.这是401里的一句话。
“The UE may be registered in multiple Tracking Areas”。这句话不知道是什么意思哦。。。一个CELL只能属于一个TA,一个UE在一个时刻只能在一个CELL里,这里怎么说一个UE可以同时在多个TA里注册呢?
