取值 | 原因值 | 意义Meaning |
无线网络层原因值Radio Network Layer cause | ||
48 | Deciphering Keys Not Available | 由于RNC不能提供要求的密钥,该动作失败。The action failed because RNC is not able to provide requested deciphering keys. |
13 | Conflict with already existing Integrity protection and/or Ciphering information | 由于要求的安全模式结构与已存在的安全模式结构冲突,该动作没有执行。The action was not performed due to that the requested security mode configuration was in conflict with the already existing security mode configuration. |
26 | Condition Violation For Guaranteed Bit Rate | 由于情况不符合保证比特率,该动作没有执行。The action was not performed due to condition violation for guaranteed bit rate. |
24 | Condition Violation For SDU Parameters | 由于情况不符合SDU参数,该动作没有执行。The action was not performed due to condition violation for SDU parameters. |
25 | Condition Violation For Traffic Handling Priority | 由于情况不符合流处理优先权,该动作没有执行。The action was not performed due to condition violation for traffic handling priority. |
49 | Dedicated Assistance data Not Available | 由于RNC不能成功发送要求的专用协助数据给UE,该动作失败。The action failed because RNC is not able to successfully deliver the requested dedicated assistance data to the UE. |
45 | Directed Retry | 定向重发导致该动作发生。The reason for action is Directed Retry |
14 | Failure In The Radio Interface Procedure | 无线接口进程失败。Radio interface procedure has failed. |
56 | Incoming Relocation Not Supported Due To PUESBINE Feature | 因为PUESBINE特性,呼入的重定位不能被目标RNC接受。The incoming relocation cannot be accepted by the target RNC because of the PUESBINE feature. |
32 | Interaction With Other Procedure | 与另一进程交互导致了重定位取消。Relocation was cancelled due to interaction with other procedure. |
30 | Invalid RAB ID | 由于在RNC上RAB ID未知,该动作失败。The action failed because the RAB ID is unknown in the RNC. |
23 | Invalid RAB Parameters Combination | 非法的RAB参数组合引起的动作失败。The action failed due to invalid RAB parameters combination. |
19 | Invalid RAB Parameters Value | 非法RAB参数值引起的动作失败。The action failed due to invalid RAB parameters value. |
28 | Iu UP Failure | Iu UP失败引起的动作失败。The action failed due to Iu UP failure. |
31 | No remaining RAB | 没有剩余RAB引起的动作失败。The reason for the action is no remaining RAB. |
1 | RAB Pre-empted | RAB预清空引起的动作失败。The reason for the action is that RAB is pre-empted. |
46 | Radio Connection With UE Lost | 由于与UE无线连接中断引起的动作请求。The action is requested due to losing radio connection to the UE |
40 | Release Due To UE Generated Signalling Connection Release | 由于UE产生了信令连接释放引发的释放请求。Release requested due to UE generated signalling connection release. |
15 | Release Due To UTRAN Generated Reason | 由于UTRAN触发的释放初始化。Release is initiated due to UTRAN generated reason. |
10 | Relocation Cancelled | 重定位取消引起该动作。The reason for the action is relocation cancellation. |
43 | Relocation Desirable for Radio Reasons | 由于无线原因引起的重定位请求。The reason for requesting relocation is radio related. |
29 | Relocation Failure In Target CN/RNC Or Target System | 由于目标CN/RNC或者目标系统中的失败引起的重定位失败。Relocation failed due to a failure in target CN/RNC or target system. |
44 | Relocation Not Supported In Target RNC Or Target System | 由于目标RNC或者目标系统不支持位置更新失败引起的重定位失败。Relocation failed because relocation was not supported in target RNC or target system. |
50 | Relocation Target not allowed | 到目标小区的重定位不被UE接受。Relocation to the indicated target cell is not allowed for the UE in question. |
6 | Relocation Triggered | 由于重定位,该动作失败。The action failed due to relocation. |
37 | Repeated Integrity Checking Failure | 由于完整性验证重复失败引起的动作请求。The action is requested due to repeated failure in integrity checking. |
39 | Request Superseded | 由于在同一个RAB上有第二个请求,该动作失败。The action failed because there was a second request on the same RAB. |
12 | Requested Ciphering And/Or Integrity Protection Algorithms Not Supported | UTRAN或者UE不支持要求的加密或完整性保护算法。The UTRAN or the UE is unable to support the requested ciphering and/or integrity protection algorithms. |
35 | Requested Guaranteed Bit Rate For DL Not Available | 由于请求的下行保证比特率不可用,该动作失败。The action failed because requested guaranteed bit rate for DL is not available. |
36 | Requested Guaranteed Bit Rate For UL Not Available | 由于请求的上行保证比特率不可用,该动作失败。The action failed because requested guaranteed bit rate for UL is not available. |
21 | Requested Guaranteed Bit Rate Not Available | 由于请求的保证比特率不可用,该动作失败。The action failed because requested guaranteed bit rate is not available. |
42 | Requested Information Not Available | 由于请求的信息不存在,该动作失败。The action failed because requested information is not available. |
33 | Requested Maximum Bit Rate For DL Not Available | 由于请求的下行最大比特率不可用,该动作失败。The action failed because requested maximum bit rate for DL is not available. |
34 | Requested Maximum Bit Rate For UL Not Available | 由于请求的上行最大比特率不可用,该动作失败。The action failed because requested maximum bit rate for UL is not available. |
20 | Requested Maximum Bit Rate Not Available | 由于请求的最大比特率不可用,该动作失败。The action failed because requested maximum bit rate is not available. |
38 | Requested Request Type Not Supported | 因为RNC不支持请求的事件或者因为它不支持请求的报告区域,RNC不支持请求的位置请求类型。The RNC is not supporting the requested location request type either because it doesn’t support the requested event or it doesn’t support the requested report area. |
51 | Location Reporting Congestion | 由于不支持过载引起的位置报告,该动作没有执行。The action was not performed due to an inability to support location reporting caused by overload. |
18 | Requested Traffic Class Not Available | 由于要求的业务类型不可用,该动作失败。The action failed because requested traffic class is not available. |
22 | Requested Transfer Delay Not Achievable | 由于要求的传输延时不可达,该动作失败。The action failed because requested transfer delay is not achievable. |
41 | Resource Optimisation | 要求重定位的原因是资源优化。The reason for requesting relocation is resource optimisation. |
11 | Successful Relocation | 完成成功重定位而触发该动作。The reason for the action is completion of successful relocation. |
17 | Time Critical Relocation | 由于时间临界的原因请求重定位,换句话说,这个原因值表示所有的不执行重定位就会导致连接中断的临界事件。Relocation is requested for time critical reason i.e. this cause value is reserved to represent all critical cases where the connection is likely to be dropped if relocation is not performed. |
5 | TQUEUING Expiry | 由于TQUEUING 时钟到时,该动作失败。The action failed due to expiry of the timer TQUEUING. |
7 | TRELOCalloc Expiry | 由于TRELOCalloc 时钟到时,重定位资源分配进程失败。Relocation Resource Allocation procedure failed due to expiry of the timer TRELOCalloc. |
4 | TRELOCcomplete Expiry | 由于TRELOCcomplete 时钟到时,该动作执行。The reason for the action is expiry of timer TRELOCcomplete. |
2 | TRELOCoverall Expiry | 由于TRELOCoverall时钟到时,该动作执行。The reason for the action is expiry of timer TRELOCoverall. |
3 | TRELOCprep Expiry | TRELOCprep 时钟到时,重定位预备进程取消。Relocation Preparation procedure is cancelled when timer TRELOCprep expires. |
8 | Unable To Establish During Relocation | 因为目标RNC不支持,重定位中RAB建立失败。RAB failed to establish during relocation because it cannot be supported in the target RNC. |
9 | Unknown Target RNC | 因为CN对目标RNC不可知,重定位被拒绝。Relocation rejected because the target RNC is not known to the CN. |
16 | User Inactivity | 由于用户在一个或几个非实时的RAB内不活动,这个动作被请求。目的是优化无线资源。The action is requested due to user inactivity on one or several non real time RABs e.g. in order to optimise radio resource. |
27 | User Plane Versions Not Supported | 因为要求的用户面版本不被支持,该动作失败。The action failed because requested user plane versions were not supported. |
47 | RNC unable to establish all RFCs | RNC不能建立所有的在RAB参数IE中表示的RAB子流程组合RNC couldn’t establish all RAB subflow combinations indicated within the RAB Parameters IE. |
52 | Reduce Load in Serving Cell | 当前服务的小区的负载需要减少。Load on serving cell needs to be reduced. |
53 | No Radio Resources Available in Target Cell | 目标小区的负载太高。Load on target cell is too high. |
54 | GERAN Iu-mode failure | RAB的建立/修改/位置更新失败,因为GERAN BSC不能提供一个恰当的RAB由于在GERAN中功能的限制。The RAB establishment/modification/relocation failed because the GERAN BSC cannot provide an appropriate RAB due to limited capabilities within GERAN. |
55 | Access Restricted Due to Shared Networks | 由于共享网络,在小区内接入未被准许。Access is not permitted in the cell due to Shared Networks. |
57 | Traffic Load In The Target Cell Higher Than In The Source Cell | 因为目标小区的业务负载大于源小区,所以拒绝由于源小区减少负载引发的重定位。Relocation to reduce load in the source cell is rejected, as the target cell’s traffic load is higher than that in the source cell. |
58 | MBMS - No Multicast Service For This UE | 因为这个UE没有任何活动的组播服务,UE的组播服务清单的请求没有履行。The request for the Multicase Service list of one UE was not fulfilled because the UE does not have any active multicast service. |
59 | MBMS - Unknown UE ID | 由于CN节点对UE的ID未知,导致该UE的组播服务清单没有被履行。The request for the Multicase Service list of one UE was not fulfilled because the CN does not know the UE. |
60 | Successful MBMS Session Start - No Data Bearer Necessary | MBMS会话开始进程成功执行,但是RNC没有有兴趣的UE。The MBMS Session Start procedure was successfully performed, but the RNC does not have any interested UE. |
61 | MBMS - Superseded Due To NNSF | 由于在另外一个CN节点实现了一个成功的操作,MBMS会话开始进程被拒绝。The MBMS Session Start procedure was rejected because of successful operation towards another CN node. |
62 | MBMS - UE Linking Already Done | 因为UE已经连接到一个给定的多点传送服务,UE的去连接失败。The UE linking failed, because the UE has already been linked to the given Multicast service. |
63 | MBMS - UE De-Linking Failure - No Existing UE Linking | 因为UE没有连接到给定的组播服务,UE的去连接失败。The UE de-linking failed, because the UE had not been linked to the given Multicast service. |
64 | TMGI Unknown | 由于TMGI是未知的,被请求的MBMS动作失败。The requested MBMS action failed because the indicated TMGI is unknown. |
扩展无线网络层原因值Radio Network Layer cause extension | ||
257 | IP Multicast Address And APN Not Valid | 由于IP组播地址和APN无效引起的MBMS注册失败。The MBMS registration failed because the IP Multicast Address and APN are not valid. |
258 | MBMS De-Registration Rejected Due To Implicit Registration | 由于隐式的注册引起的MBMS注销拒绝。The MBMS De-registration was rejected because of implicit registration. |
259 | MBMS - Request Superseded | 由于另外一个正在执行的进程,MBMS的注册和注销被取代。The MBMS Registration or De-registration was superseded due to another ongoing procedure. |
260 | MBMS De-Registration During Session Not Allowed | 在MBMS会话中不允许MBMS注销。The MBMS De-registration is not allowed during the MBMS session. |
261 | MBMS - No Data Bearer Necessary | RNC不再有任何对MBMS数据承载电路有兴趣的UE。The RNC no longer have any UEs interested in the MBMS data bearer. |
传输层原因值Transport Layer cause | ||
66 | Iu Transport Connection Failed to Establish | 由于Iu传输网络层连接不能建立,该动作失败。The action failed because the Iu Transport Network Layer connection could not be established. |
65 | Signalling Transport Resource Failure | 信令传输资源失败。(如进程重置)Signalling transport resources have failed (e.g. processor reset). |
NAS原因值NAS cause | ||
83 | Normal Release | 正常释放。The release is normal. |
81 | User Restriction Start Indication | 生成一个位置报告由于进入一个由O&M设置的等级区域。A location report is generated due to entering a classified area set by O&M. |
82 | User Restriction End Indication | 生成一个位置报告由于离开一个由O&M设置的等级区域。A location report is generated due to leaving a classified area set by O&M. |
协议原因值Protocol cause | ||
100 | Abstract Syntax Error (Reject) | 这个接收到得消息包含了一个抽象的语法错误和相关的关键点表明”reject”。The received message included an abstract syntax error and the concerning criticality indicated "reject". |
101 | Abstract Syntax Error (Ignore And Notify) | 这个接收到的消息包括一个抽象的语法错误和有关的临界表示”忽略和通知”。The received message included an abstract syntax error and the concerning criticality indicated "ignore and notify". |
102 | Abstract Syntax Error (Falsely Constructed Message) | 这个接收到的消息包含了在错误排序或者太多的事件的IEs或者IE组。The received message contained IEs or IE groups in wrong order or with too many occurrences. |
99 | Message Not Compatible With Receiver State | 这个接收到得消息和接收机的状态不匹配。The received message was not compatible with the receiver state. |
98 | Semantic Error | 这个接收到得消息包含了一个语义上的错误。The received message included a semantic error. |
97 | Transfer Syntax Error | 这个接收到得消息包含了一个传输语法错误。The received message included a transfer syntax error. |
其他原因值Miscellaneous cause | ||
116 | Network Optimisation | 这个动作完成网络的优化。The action is performed for network optimisation. |
114 | No Resource Available | 没有可用的请求资源。No requested resource is available. |
113 | O&M Intervention | 这个动作是取决于O&M的插入。The action is due to O&M intervention. |
115 | Unspecified Failure | 当没有特定的原因值相符时发送。Sent when none of the specified cause values applies. |
