MS在进入SGSN2的路由区后会发送RAU Request消息给SGSN2,该消息中就包含了MS Radio Access capability。所以SGSN2不用去向SGSN1去要,MS就直接告诉它了。然后如果BSC通过Radio Access Capability Update消息向SGSN2请求终端能力时,SGSN2将通过RA-CAPABILITY-UPDATE-ACK PDU 并包含MS的终端能力返回给BSC。
“The BSS may request an MS's current Radio Access capability and/or its IMSI by sending to an SGSN a RA CAPABILITY-UPDATE PDU which includes the TLLI of the MS and a Tag. The allocation of the Tag is implementation specific. The BSS then starts timer T5.
The SGSN shall respond by sending a RA-CAPABILITY-UPDATE-ACK PDU which includes the TLLI of the MS, the Tag received in the corresponding RA-CAPABILITY-UPDATE PDU, and an RA-Cap-UPD-Cause field; the IMSI of the MS is also included when known. The BSS shall stop timer T5.
If the RA-Cap-UPD-Cause is set to "OK", then an MS Radio Access Capability field and the IMSI shall be present. The received MS's radio access capability, if valid, shall then replace any radio access capability previously associated with the MS. If the RA-Cap-UPD-Cause is not set to "OK", then neither the MS Radio Access Capability nor the IMSI shall be present in the RA-CAPABILITY-UPDATE-ACK PDU."
