/Image._Foxmail.0(07-11-21-53-30).jpg)
/Image._Foxmail.1(07-11-21-53-30).jpg)
重试次数和等待时间都有的。有关于等待对方报文的等待时间,BSS侧是T6计时器(发送DOWNLOAD-BSS-PFC PDU 启动 ,收到CREATE-BSS-PFC PDU后停止),SGSN侧是T7计时器(发送CREATE-BSS-PFC-ACK PDU启动,收到CREATE-BSS-PFC-NACK PDU停止)。
SGSN的重试次数是:“If a CREATE-BSS-PFC-ACK or CREATE-BSS-PFC-NACK PDU is not received in response to a CREATE-BSS-PFC PDU within T7 seconds, then the CREATE-BSS-PFC PDU shall be repeated a maximum of CREATE-BSS-PFC-RETRIES attempts. After CREATE-BSS-PFC-RETRIES+1 attempts the procedure is stopped and the O&M is informed.”
也就是SGSN上有一个叫做CREATE-BSS-PFC-RETRIES的重传次数定义的。
BSS上也有一个,如下“If a CREATE-BSS-PFC PDU is not received for a DOWNLOAD-BSS-PFC PDU within T6 seconds, then the DOWNLOAD-BSS-PFC PDU shall be repeated a maximum of DOWNLOAD-BSS-PFC-RETRIES attempts. After DOWNLOAD-BSS-PFC-RETRIES + 1 attempts the procedure is stopped and the O&M system is informed. If a BSS PFC is not received then the BSS shall handle uplink and downlink transfers according to a best-effort default aggregate BSS QoS profile.”
叫做DOWNLOAD-BSS-PFC-RETRIES计时器。
但这里的问题是SGSN为什么要重发BSS-PFC PDU?因为上面的计时器是指收不到BSS的BSS-PFC-ACK PDU来重发的,本例是已经收到了,所以最好有抓包看看,是不是协商有什么问题。
snap0127 发表于 2012-7-16 11:18
从我的包上来看,SGSN发送“CREATE-BSS-PFC”到收到“CREATE-BSS-PFC-ACK”结束。而你说“发送CREATE-BSS-P ...
原话是这样的“Following a DOWNLOAD-BSS-PFC PDU if there is not an ongoing Delete PFC procedure for that corresponding PFI, the SGSN shall send a CREATE-BSS-PFC PDU to the BSS with a requested Aggregate BSS QoS Profile and start timer T7. ”。
规范是TS48.018 BSSGP协议。
