[attach]245[/attach]
Figure 48: Insert Subscriber Data Procedure
1) The HLR sends an Insert Subscriber Data (IMSI, Subscription Data) message to the SGSN.
1)HLR发送插入签约用户数据(IMSI,签约用户数据)消息给SGSN.
2) The SGSN updates its GPRS subscription data and acknowledges the Insert Subscriber Data message by returning an Insert Subscriber Data Ack (IMSI) message. For each PDP context that is included in Subscription Data the SGSN shall check whether it is a new, an active, or an inactive PDP context:
2)SGSN更新它的GPRS签约用户数据并且返回一个插入签约用户数据ACK(IMSI)消息进行确认.对每个包含在签约数据中的PDP上下文,SGSN应检查它是不是新的、一个active的、或是inactive的PDP上下文;
For architecture variants using Gn/Gp based interaction with GGSN the PDP contexts are handled as follows:
如果基于Gn/Gp架构,那和GGSN的交互,PDP上下文的处理应如下进行:
- For a new or inactive PDP context, no further action is required except storage in the SGSN.
- For an active PDP context, the SGSN shall in addition compare the new QoS Subscribed with QoS Negotiated, new Subscribed Evolved ARP with the previously stored Subscribed Evolved ARP, respectively and shall, if necessary and MS is in the READY or PMM CONNECTED State, initiate a PDP Context Modification procedure as described in clause "Modification Procedures". If modification is necessary, when MS is not in the READY or PMM CONNECTED State, or the modification is not successful when MS is in the READY or PMM CONNECTED State, the SGSN shall directly delete the concerned PDP context(s).
- 对于一个新的或inactive的PDP上下文,除了存储在SGSN的数据外没有后续的行动要求.
- 对于一个active的PDP上下文,SGSN应额外将新的签约的QOS和协商的QOS进行对比,新的签约的演进ARP和之前存储的签约的演进ARP等。并且,如果有必要并且MS是在READY或PMM-CONNECTED状态,将发起一个PDP上下文修改流程(在章节"Modification Procedures")描述.如果修改是必要的,当MS不是在READY或PMM-CONNECTED状态,或者当MS在READY或PMM-CONNECTED状态下的修改不成功,SGSN应直接删除这些相关的PDP上下文。
PDP Context Modification due to changes in Subscribed Evolved ARP may be skipped if there is no previously stored value for Subscribed Evolved ARP.
因为签约的演进ARP的变化而产生的PDP上下文修改可以被跳过---如果之前没有存储签约的演进ARP值的话。
- For an MS in PMM-CONNECTED State and connected via a CSG or hybrid cell, the SGSN shall check the received CSG subscription data. If the SGSN detects that the UE's CSG membership to that cell has changed or expired, the SGSN initiates the procedure in clause 9.2.3.7.
For architecture variants using S4 based interaction with S GW and P GW, the PDP contexts are handled as follows:
- For an active PDP context, the SGSN shall in addition compare the new QoS Subscribed with bearer QoS and shall, if necessary and MS is in the READY or PMM CONNECTED State, initiate a PDP Context Modification procedure as described in clause "Modification Procedures". If modification is necessary, when MS is not in the READY or PMM CONNECTED State, or the modification is not successful when MS is in the READY or PMM CONNECTED State:
- 对于一个PMM-CONNECTED状态的MS并通过一个CSG或混杂小区连接的,SGSN应检查接收到的CSG签约数据。如果SGSN检测到UE的关于这个小区的CSG成员关系变化或超时,SGSN应发起章节9.2.3.7提到的流程。
对于基于S4接口的架构体系,要和SGW和PGW交互,那PDP上下文将按如下处理:
- 对于一个新或inactive的PDP上下文,除了存储在SGSN内的数据外,没有而外的行动要求。
- 对于一个active的PDP上下文,SGSN应额外将新的签约的QOS和的承载的QOS进行对比,如果有必要并且MS是在READY或PMM-CONNECTED状态,将发起一个PDP上下文修改流程(在章节"Modification Procedures")描述.如果修改是必要的,当MS不是在READY或PMM-CONNECTED状态,或者当MS在READY或PMM-CONNECTED状态下的修改不成功,那么:
a) If ISR is activated when the next activity from MS is detected the S4-SGSN shall compare the stored updated subscription data with the existing data for that PDP context and initiate modification procedure.
b) If ISR is not activated, the SGSN shall directly delete the concerned PDP context.
Furthermore, if VPLMN Address Allowed is changed, the SGSN shall, if necessary (e.g., if the PDP context is currently routed via a GGSN in the VPLMN and VPLMN Address Allowed is changed to not allowed), initiate a PDP Context Deactivation procedure as explained in clause 9.2.4.
a) 如果ISR激活了,当从MS来的下一个活动时间检测到的时候,S4-SGSN应对比存储的更新的签约数据和已经存在的PDP上下文的数据,并发起修改流程。
b)如果ISR没有激活,那SGSN应直接删除相关连的PDP上下文。
- 对于处于PMM-CONNECTED状态的MS并通过一个CSG或混杂小区连接,SGSN应检查接收到的CSG签约数据。如果SGSN检测到UE的关于这个小区的CSG成员关系变化或超时,SGSN应发起章节9.2.3.7提到的流程。
除此以外,如果"VPLMN地址允许"标识变化,SGSN应,如果有必要(例如.,如果PDP上下文当前正经过VPLMN的GGSN进行路由并且"VPLMN地址允许"标志变成了不允许),按照章节9.2.4提到的发起一个PDP上下文的去激活流程。
6.11.1.2 Delete Subscriber Data Procedure
In addition to the deletion of general subscription data for a subscriber, see TS 29.002 [23], the HLR may request the deletion of one or several PDP contexts from the SGSN.
The Delete Subscriber Data procedure is illustrated in Figure 49.
详细的删除通用签约用户数据的流程,可参考TS29.002.HLR可以请求让SGSN删除一个或多个PDP上下文.Delete Subscriber Data流程由图例49描述。
[attach]246[/attach]
Figure 49: Delete Subscriber Data Procedure
1) The HLR sends a Delete Subscriber Data (IMSI, PDP Context Identifiers List) message to the SGSN.
2) The SGSN acknowledges the Delete Subscriber Data message by returning a Delete Subscriber Data Ack (IMSI) message. For each PDP context identifier included in PDP Context Identifiers List, the SGSN shall check whether it belongs to an active or an inactive PDP context:
- For an inactive PDP context no further action is required except deletion of the PDP context.
- For an active PDP context, the SGSN shall initiate the PDP Context Deactivation Initiated by the SGSN procedure as explained in clause "Deactivation Procedures" before the PDP context is deleted.
1)HLR发送delete subscriber data(IMSI,PDP上下文ID列表)消息给SGSN.
2)SGSN返回一个Delete Subscriber Data Ack (IMSI)消息进行确认。对包含在PDP上下文列表当中的每一个PDP上下文ID,SGSN应检查是否属于一个active或inactive的PDP上下文:
- 对于一个inactive的PDP上下文,除了删除这个PDP上下文外,没有额外的行动要求。
- 对于一个active的PDP上下文,SGSN应在PDP上下文删除之前,发起由章节"Deactivation Procedures"所描述的SGSN发起的PDP上下文去激活流程。
主要就那么几个,不会太多。包括签约的APN、是否开通GPRS业务、本地区域的接入限制、是否允许漫游、签约的Qos等。
其中APN和Qos以及是否开通了GPRS业务是重点。
