By sending a RAB Release Request or IuRelease Request message to the SGSN, an Iu mode RAN initiates the release ofone or more RABs. The preservation procedure allows the active PDP contextsassociated with the released RABs to be preserved in the CN, and the RABscan then be re-established at a later stage, see clause 9.2.5.2and clause 9.2.3.5.
An Iu mode RAN uses the Iu Release Requestto request release of all RABs of an MS, and the RAB Release Request in othercases.
By sending a RAB Release Request or IuRelease Request message to the SGSN, an Iu mode RAN initiates the release ofone or more RABs. The preservation procedure allows the active PDP contextsassociated with the released RABs to be preservedin the CN, and the RABscan then be re-established at a later stage, see clause 9.2.5.2and clause 9.2.3.5.
然后我认为保留的话也有好处呀,至少你下次做业务的时候可能只要重建个RAB就可以了,这样的话流程肯定会更快一点,做业务当然就更快。如果你重新走激活流程的话时间肯定会稍微长一点嘛,以前不是说什么“永远在线”的吗?不就是让用户感觉他好像没有脱离这个这个网络,随时可以进行业务吗?个人见解,爱总再帮我点拨一下。
The procedure for re-establishment of RABs allows the SGSN to re-establish RABs for active PDP contexts that don't have an associated RAB.
The MS initiates the re-establishment of RABs by using the Service Request (Service Type = Data) message. This is described in the sub-clause "MS Initiated Service Request Procedure". SGSN shall not establish RABs for PDP contexts with maximum bit rate for uplink and downlink of 0 kbit/s. For these PDP contexts, the MS shall perform a MS-initiated PDP Context Modification or Deactivation procedure.
When RABs for an MS that has no RRC connection needs to be re-established, the CN must first page the MS. The clause "Network Initiated Service Request Procedure" describes this.
6.12.1
4)
If the network is in PMM-CONNECTED state and the Service Type indicates Data, the SGSN shall respond with a Service Accept message towards the MS, in case the service request can be accepted. In case Service Type indicates Data, the SGSN sends a Radio Access Bearer Assignment Request (NSAPIRAB ID(s), TEID(s), QoS Profile(s), SGSN IP Address(es)) message to re-establish radio access bearer for every activated PDP context, except the ones having maximum bit rates for uplink and downlink of 0 kbit/s.
By sending a RAB Release Request or Iu Release Request message to the SGSN, an Iu mode RAN initiates the release of one or more RABs. The preservation procedure allows the active PDP contexts associated with the released RABs to be preservedin the CN, and the RABs can then be re-established at a later stage, see clause 9.2.5.2 and clause 9.2.3.5.
An Iu mode RAN uses the Iu Release Request to request release of all RABs of an MS, and the RAB Release Request in other cases.
这段说的难道不是这个事?hycl5410 发表于 2012-2-25 16:36
回复 jianglibing 的帖子
9.2.5.2
Re-establishment of RABsThe procedure for re-establishment of RABs ...
谢谢你的补充。我这个墙头草觉得你说得很有道理。呵呵。应该是RAB的释放流程,而不是PDP的去激活。
所以根据你的提示。总结一下这个问题。欢迎继续纠错。
“就是如果说有保留机制的话,那就是如果RAB因为某种原因(可能是无线信号不好、也可能是假设手机看小说,过长时间没有翻页)释放后,PDP上下文仍有可能会被保留,MM状态将切换到PMM-Idle。这样对UE来讲是透明的,用户可以重建RAB而不是重新发起PDP激活流程来访问后续的数据业务。但如果发生了PDP的去激活流程,那PDP上下文应该是会被删除的。”
