InterNetwork Expert CCIE Service Provider WorkBook Vol II Lab系列是完全模拟CCIE考试环境的Lab实验手册。可以自行安装模拟器按照文中的拓扑搭建实验环境,并自己先做,然后再针对给出的正确答案看自己是否回答正确,从而对自己的思科认证水平有更细致的了解,也方便去准备相关的认证考试。
每个Lab都包含了拓扑图,需求和正确答案三个部分。本帖是关于Lab 10的。实验拓扑如下:
[attach]1058[/attach]
部分需求摘抄如下:
1.4. ATM PVCs
• Configure an ATM hub-and-spoke network between R1, R2, and R9 using
the VPI/VCI information contained in the diagram.
• Do not rely on static or dynamic protocol resolution to accomplish this. 3 Points
2. Interior Gateway Routing
2.1. OSPF
• Configure OSPF area 0 on all of the transit links between R1, R2, R3, R4, R5, and R9.
• Advertise the Loopback0 networks of these devices into OSPF area 0. 3 Points
3. Exterior Gateway Routing
3.1. IPv4 BGP Peerings
• Configure BGP AS 200 on R1.
• Configure BGP AS 100 on R6.
• Configure BGP AS 65001 on R7.
• R6 should peer with BB1.
• R7 should peer with R1 and BB2.
• BB2 will be expecting R7 to be in AS 200 and use an MD5 hash of the
password CISCO.
• Do not use the as-override or allowas-in commands to accomplish this. 4 Points
3.2. VPNv4 BGP Peerings
• Configure AS 200 on R1, R4, and R5.
• R4 should peer with R1, R5, and R6 via VPNv4.
• Do not exchange any other address families between these peers.
• Use the minimum amount of configuration to accomplish this. 3 Points
4. MPLS
4.1. MPLS Tunneling
• AS 200 will be providing MPLS VPN services to its customers via the PE routers R1, R4, and R5.
• Configure AS 200 to support MPLS tunnels on all possible links in the transit path between these devices.
• Do not use LDP or TDP to accomplish this. 3 Points
[attach]1059[/attach]
