标题: DNS Query的问题 [打印本页]
作者: sima.yuchan    时间: 2012-1-10 08:58:14     标题: DNS Query的问题
DNS Query的具体细节我不懂,分析不了具体啥意思,
I have tested DNS query Cause procedure. I have tried many times, SGSN shall query DNS every 1 min (TimeToLive 60sec) and SGSN is acting accordingly (doesn’t query DNS within one minute from the last query). Despite this UBAS is reporting as if SGSN is querying the SGSN in those intervals (less than 1min).You can compare it with the SGSN trace where only three DNS queries/answers are visible whereas in UBAS in the same time six events are recorded.
局方反馈的问题,意思就是说DNS Query ,频率间隔最少1分钟?
作者: 海浪    时间: 2012-1-29 14:29:16
查一下DNS query是同一个APN还是不同的APN。DNS服务器一般都设置了APN A记录的timeout值,这个值会缓存在SGSN中, 在第一次query后,SGSN就会cache在缓存中,这样就减少了每次都需要访问DNS。等这个缓存值timeout后,然后才会去再query DNS。如果没有设置缓存值也就是设置成0, 那么就意味着不缓存在SGSN中,每次只要有请求这个记录就会访问DNS服务器,那query的频率就高。DNS Query ,频率间隔最少1分钟是不是DNS服务器设置了什么安全的策略?
作者: 海浪    时间: 2012-1-29 14:29:42
作者: 海浪    时间: 2012-1-29 14:29:59
