标题: 请问 哪个版本的3GPP有彩信方面的规范说明呢? [打印本页]
作者: hendouse    时间: 2011-12-6 17:02:41     标题: 请问 哪个版本的3GPP有彩信方面的规范说明呢?
    请问 哪个版本的3GPP有彩信方面的规范说明呢?     谢谢  {:soso_e183:}
作者: admin    时间: 2011-12-27 20:09:21
回复 hendouse 的帖子
There are two important standards that define MMS technology, one published by the 3GPP (3GPP TS 23.140), and the other a series of MMS specifications published by the Open Mobile Alliance (OMA). These two standard bodies cooperate to define the MMS protocols.
When MMS is discussed, you will often hear details of different MMS related protocols, such as MM1, MM3, MM4, MM7, as well as proprietary protocols such as EAIF, and various vendor specific proprietary variations of MM7. (You might also wonder about MM2, MM5, MM6, MM8, MM9, and others, but they are beyond the scope of this document, and are defined in 3GPP TS 23.140.)
http://www.nowsms.com/faq/how-mms-works
  另外,还有个TS26.140定义了Multimedia Messaging Service (MMS); Media formats and codecs。
作者: hendouse    时间: 2011-12-28 09:06:24
回复 admin 的帖子
请问管理员有这个3GPP规范的文档吗?如有,希望共享给大家。
   谢谢~{:soso_e100:}{:soso_e181:}
作者: 爱卫生    时间: 2011-12-31 10:29:32
回复 hendouse 的帖子
TS23.140 :http://www.3gpp.org/ftp/Specs/html-info/23140.htm
TS26.140 :http://www.3gpp.org/ftp/Specs/html-info/26140.htm
